Author Topic: Ed30 induction kit  (Read 3950 times)
Offline MaverickFSI
  • Tornado Red Ed30 DSG
Ed30 induction kit
« on: February 18, 2012, 07:02:12 pm »
Hello chaps,
Was wondering if anyone could recommend an induction kit that gives a more 'throaty' response BUT doesn't require you to butcher your standard engine cover.
Many thanks.
Great balls of fire!
Retro Dubs on the go;
'91 Corrado 20vT - Project still going... and going...
Saintsteve
Re: Ed30 induction kit
« Reply #1 on: February 18, 2012, 07:07:08 pm »
Buy a 2nd hander engine cover, keep your old one and fit a Forge TTake  :signLOL:
Or just put your cover for safe keeping and don't bother with a cover.
Offline ktlstar
« Reply #2 on: February 18, 2012, 10:35:16 pm »
Itg mate
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline jedi-knight83
  • -Receive: 41
« Reply #3 on: February 19, 2012, 09:32:15 am »
You can get the carbonaro thing that just goes onto the front of the engine cover but I cannot see the point in those at all as the air still has to pass through the standard intake as the engine cover has the airbox built into it.
The other suggestions all replace the engine cover (unless you cut it up) but provide much better gains.
ITG and Forget TwinTake seem the most popular or the Nuspeed p-Flo as a cheaper option.
  • -Receive: 291
« Reply #4 on: February 19, 2012, 10:35:12 am »
Doesn't the GruppeM intake utilise the standard engine cover?
Offline MaverickFSI
« Reply #5 on: February 19, 2012, 12:15:33 pm »
Well I'm not sure but the price is just ridiculous - http://www.ppcgb.com/Gruppe-M-Carbon-Fibre-Performance-Ram-Air-Induction-Kit---VW-Golf-MK5-GTI-Turbo/prod14382/
Is there a guide to what you need to do to get the more established kits i.e. Forge/ITG to fit using the standard engine cover?
Anybody used or heard of the EVOMS kit - http://www.regal-shop.co.uk/vw/acatalog/copy_of_copy_of_copy_of_Golf_MK5_Edition_30.html - 2nd one down on page.
Cheers.
  • -Receive: 291
« Reply #6 on: February 19, 2012, 02:21:16 pm »
The GruppeM will use the standard cover. Anything else will require you to chop the standard cover, use an EVOMS cover, or just run without the cover.
Offline MaverickFSI
« Reply #7 on: February 19, 2012, 02:41:17 pm »
Yeah fair point. Unless you really want to be different and go with a GruppeM kit you could, instead, get a EVOMS engine cover and kit with over 200 quid change.
Do you know of anyone who has ran the GruppeM on their GTI?
Personally I'd like to retain some sort of engine cover be it a 'modified' OEM or a purpose built alternative like the EVOMS. I think the EVOMS engine cover maybe prove a better choice as when you decide to go back to standard you can fit your original one again.
What sort of performance figures could you expect with a, for example, REVO stage 1 and induction kit?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #8 on: February 19, 2012, 03:36:57 pm »
TT-S engine cover with ITG/Twintake/EVOMS/whatever takes your fancy
PLANS: Stage 2+
h4rdy
« Reply #9 on: February 19, 2012, 03:50:19 pm »
I have had both ITG(BDM copy) and the TwinTake now back to standard.
Ill be honest, I couldn't stand the noise of either, I am old(er)!
If the noise isn't an issue go for the ITG without a shadow of doubt my car had issues with the Forge and just would not adapt.
The ITG was so brutal though with Stage 2+ I had to take it off, that and the noise.
I have a Pipercross panel now and yes power drops but its much nicer to drive.
Also I found the engine can get quite dirty with no cover.
The Gruppe B looks nice though and don't forget about the BSH truseal(?)
I am considering getting hold of an engine cover and seeing if I can make it flow a bit better at work, I have access to a machine shop, without all the whooshing but with the chattering, I love that.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #10 on: February 19, 2012, 05:50:44 pm »
do forget about the BSH true seal. it does the job and looks nice and OEM but it has fitting issues with Euro spec cars and their customer service is horrible. the only reason mine is still on my car is because it's hassle taking it off again.
if you want cheap and cheerful but quite good quality go for a Neuspeed P-Flo.
« Last Edit: February 19, 2012, 05:53:38 pm by sub39h »
PLANS: Stage 2+
Offline MaverickFSI
« Reply #11 on: February 19, 2012, 07:26:01 pm »
Thanks for the replies chaps, some good points/advice there.
So regarding the TT-S engine cover, does it offer up straight onto the existing locators?
What's this BSH true seal you speak of? Never heard of it?
What do you guys think of this - http://www.awesome-gti.co.uk/product.php?xProd=8047&xSec=10924 - Any good?
Thanks again.
Offline Janner_Sy
  • -Receive: 113
« Reply #12 on: February 19, 2012, 07:32:18 pm »
Thanks again.
I was given one and took it off because it was embarassing.
Offline MaverickFSI
« Reply #13 on: February 19, 2012, 10:14:14 pm »
Thanks again.
Really, in what sense? Was it a bit too noisey?
So the proper diverter valve is the way to go then?
Offline Janner_Sy
  • -Receive: 113
« Reply #14 on: February 19, 2012, 10:15:52 pm »
Sounds like the airbrake releasing on a lorry
