Author Topic: Rs4 help fitting  (Read 1630 times)
Offline ktlstar
Rs4 help fitting
« on: February 18, 2012, 10:39:20 pm »
What tools will help me get the oem culprit out, and do you attempt this from the top or the side (fuelpump)
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Re: Rs4 help fitting
« Reply #1 on: February 18, 2012, 11:03:58 pm »
It's a very fiddly job if you haven't done it before. Some have used specially bent spanners or crows feet to install the valve.
I paid one hour's labour to get mine done.  :smiley:
Offline ktlstar
« Reply #2 on: February 18, 2012, 11:07:10 pm »
Hmmm, maybe worth doing that then spending money on spanners.
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #3 on: February 19, 2012, 09:45:08 am »
It took me about 25 mins, I did have the whole front end off because I was fitting my THS cooler, moved my DV out the way and brackets, I got it out with a normal spanner
HTH
Jack
www.distinctdetailing.co.uk
Offline ktlstar
« Reply #4 on: February 19, 2012, 09:54:31 am »
Jack - your sayin if i move the DV out the way, i can get to it ? Ill have a look how its attached!
Offline JackG
  • -Given: 33
  • -Receive: 31
« Reply #5 on: February 19, 2012, 02:09:30 pm »
Yes move the DV and the bracket and you can get a spanner up there
Jack
Offline ktlstar
« Reply #6 on: February 21, 2012, 01:48:15 pm »
Cheers Jack, I managed to swap it over.
Took me a good 45-1hour to remove the oem valve.
Then an extra 30-45min to put everything back..
« Reply #7 on: February 21, 2012, 02:28:19 pm »
Well done...  :happy2:
Offline ktlstar
« Reply #8 on: February 21, 2012, 03:34:57 pm »
Was worth a pop. No special tools required!
Offline gillm
« Reply #9 on: February 21, 2012, 03:46:21 pm »
Cool if anyone else does it I have a old spanner I ground up if needed
west tuned gt28 @ 340hp
