Author Topic: Finally lowered!! Strange bearing noise?  (Read 2116 times)
Offline neil86
« on: February 21, 2012, 07:59:48 am »
So I have lowered my car on eibach coilovers and fitted my 18"s made up with the drive and looks but I have noticed what can only be described as a bearing noise when slowing down braking or turning mainly at lows speeds 30 and under!!
Any help? Diagnosis.
Offline Beddie
  • -Receive: 76
Re: Finally lowered!! Strange bearing noise?
« Reply #1 on: February 21, 2012, 08:03:06 am »
Could be a top mount on it's way out?
Carbon Grey Edition 35 - Here
Offline neil86
« Reply #2 on: February 21, 2012, 10:09:06 am »
I replaced all 4 at same time as fitting the coilovers Thursday. It's like a whining noise bit like wheel bearing or tyre noise
Offline dav-aberdeen
« Reply #3 on: February 21, 2012, 11:15:06 am »
Arb not hitting the driveshaft or anything?
Offline neil86
« Reply #4 on: February 21, 2012, 01:20:57 pm »
Didn't think it affected the mk5 that issue
Offline higher1
« Reply #5 on: February 21, 2012, 01:31:04 pm »
Are you using different wheels and tyres than before lowering? Worn tyres?
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
Offline gazon69
« Reply #6 on: February 21, 2012, 02:47:31 pm »
How low have you gone bud, it may be rubbing on the front wheel arch screw. Have you done the arch screw mod
Offline neil86
« Reply #7 on: February 21, 2012, 03:23:19 pm »
Unshore how low got about 15mm maybe 20mm I could go lower on front bowt 2-3 threads left and the gap at end of threads where the seat would go. On the eibachs.
Not the arch as I am running 215 40 18 for stretch don't think I have hit it yet.
Also it's when I am going slow not over bumps or any thing weird. Oh falken tyres also may make a difference gona try my old wheels tonight.
Offline neil86
« Reply #8 on: February 21, 2012, 06:15:28 pm »
Rite changed wheels over no difference. So raised it up by 25mm bit better but still there. Gona raise more but unsure standard height from wheel centre to arch at moment 14"
Offline gazon69
« Reply #9 on: February 21, 2012, 06:35:15 pm »
I had mine slammed mate. Coilies wound fully down and only rubbing i got was on the arch screw. Something dont sound right there mate.
Offline Phil Miller
  • -Given: 86
« Reply #10 on: February 21, 2012, 06:38:00 pm »
Sometimes and i mean sometimes mine does this and its on 18s and coilovers, nothing rubbing or touching anywhere, id done 30k like it and its no worse than it was to start with, ive just put up with it so far
Offline neil86
« Reply #11 on: February 21, 2012, 07:10:30 pm »
This is doing it all the time at low speeds just reminds me of a wheel bearing going. They were fine an no noise till I fitted the coils and lowered it. It gets worse turning at low speeds but since raising and changing wheels not as bad. Weird unsure  were to begin to look no rubbing on shafts or anything has to be a bearing somewere or drive shafts not a mechanic so guess work.
Offline Little_Dave
« Reply #12 on: February 21, 2012, 09:52:57 pm »
Still got a slight knocking noise on mine when i've left the car for a while, it goes after a few hundred feet down the road, so far changed the top mounts and bearings and can't see anything touching underneath the car, got some new subframe bolts to try next aswell as a good looking over on a pit instead of a ramp so i can see the suspension compressed and check for any contact better  :wink:
Dave
Offline dub singh
  • Snakebite Chasers...
« Reply #13 on: February 21, 2012, 10:39:56 pm »
Had a similar knocking problem when the car was dropped, changed the topmount bearings and it still persisted... took the 18's off for winter and the noise went away...
will find out next week when the wheels come back on if its still there
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Offline neil86
« Reply #14 on: February 22, 2012, 07:19:28 am »
weird mine isnt knocking, is there only wheel bearings up front or is there diff bearings also? I have read you can get strange noises if 4 wheel alignment is out i havnt had it done yet as only done 50mile was waiting for it to settle for a week.
