Author Topic: Neuspeed pulley kit  (Read 2011 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Over the top mod list ;o)
Re: Neuspeed pulley kit
« Reply #1 on: April 30, 2009, 03:39:14 pm »
Don't forget to add nice Mr Brown's sh*tty tax on importing.
I'd check out how good or not this mod is. I don't trust all of Neuspeed's products - Some are entirely unnecessary. IIRC, there's a downside I read a long time ago about this mod.
Offline Harm
« Reply #2 on: May 01, 2009, 08:21:11 am »
I would also like to know the advantages of having this product?
Bit more rev happy? What do you actually achieve from having it fitted?
Thanks in advance
  • -Given: 243
  • -Receive: 154
« Reply #3 on: May 01, 2009, 09:38:46 am »
Since i've just had the car dynoed, i plan to dyno it afterwards, in the us the have had results where they lost a bit of HP but gained torque instead.
I'll let you know when i get it dynoed
Offline Harm
« Reply #4 on: May 01, 2009, 10:44:54 am »
Thanks look forward to seeing the results...
« Reply #5 on: May 01, 2009, 11:17:54 am »
I'll not bother then :innocent:
I'll swap someone a few torques in exchange for some bhp though :signLOL:
Offline animal
  • .:R32
« Reply #6 on: May 01, 2009, 12:28:43 pm »
First thing to bare in mind is you aren't actually gaining anything - the power is already there, this just a similar to transmission loss. Under-run pulleys are a bit of gimmick and often don't 'reclaim' the power they claim to. I'm not sure you'd want to start under-running the alternator, especially if you have a lot of ICE or a smaller light weight battery.
If could see hard dyno-proven evidence on a real car and not Neuspeed's super-duper-magic 'CAD' generated figures then I might be convinced otherwise but I think I'd give this one a miss. You're not going to notice any real noticeable difference in engine pick up or power on the road. With turbo engines it's all about the torque, which does the actual work. Under-run pulleys are probably better suited to N/A engines where every little helps and there is less torque to over come parasitic drag from alternators, various pumps and other engine driven ancillaries.
