Author Topic: wheel spacers  (Read 5300 times)
Offline Russ_leeds
wheel spacers
« on: February 24, 2012, 10:44:13 pm »
Hi all, I've just had my NQSBBK fitted, and had to get some 3mm universal spacers to get me home. I want to change these to some 5mm hubcentric ones as the clearance is minimal on the 3mm and I dont trust universal ones.
Has anyone got any suggestions on which ones to go for? Will I also need longer wheel bolts for 5mm spacers? and is it worth doing the rear aswell mainly for stance and to widen the track?
cheers
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: wheel spacers
« Reply #1 on: February 24, 2012, 10:52:03 pm »
5mm won't be true hubcentric spacers i.e they won't have the lip.
Offline Russ_leeds
Re: wheel spacers
« Reply #2 on: February 24, 2012, 10:58:41 pm »
so should i just stick with the 3mm ones i have then? whats the smallest hubcentric spacers you can get?
  • -Given: 32
  • -Receive: 78
Re: wheel spacers
« Reply #3 on: February 24, 2012, 11:01:22 pm »
I think 10mm is the smallest you'll find with a lip. Unless you're doing it for cosmetic reasons I'd stick with the 3mm ones.
Offline Russ_leeds
Re: wheel spacers
« Reply #4 on: February 24, 2012, 11:03:02 pm »
cheers mate, not sure now. The stance would be a lot better especially as its lowered :party:
Offline vRS_Pagey
  • -Receive: 59
Re: wheel spacers
« Reply #5 on: February 24, 2012, 11:05:15 pm »
I'm surprised the NQSBBK doesn't fit behind Monza 2's?  :popcornsoda:
If you are running a spacer of any size I would be inclined to change the bolts to match.
« Last Edit: February 24, 2012, 11:06:49 pm by vRS_Pagey »
  • -Given: 32
  • -Receive: 78
Re: wheel spacers
« Reply #6 on: February 24, 2012, 11:08:01 pm »
Monzas need spacers IMO. You'll really notice an improvement with 10mm all round. I went for 15mm at the rear and 10mm at the front.
Re: wheel spacers
« Reply #7 on: February 24, 2012, 11:12:06 pm »
I think you can get 5 mil hub centric spacers. When DaveB was putting my kit together he found a company that does them i seem to remember. Also i ran normal 3 mil spacers with no problems. As long as you check all the parts regular they should be fine.  :happy2:
Offline Russ_leeds
Re: wheel spacers
« Reply #8 on: February 24, 2012, 11:13:44 pm »
I didnt think they did until the wheels didnt go back on :signLOL:
Will the 3mm be ok on standard bolts until i get some bigger spacers sorted?
cheers
Re: wheel spacers
« Reply #9 on: February 24, 2012, 11:15:06 pm »
cheers
Yep the will be ok just keep checking them unitl you get bigger bolts.  :happy2:
Offline Russ_leeds
Re: wheel spacers
« Reply #10 on: February 24, 2012, 11:22:52 pm »
whats the best place to get some hubcentric spacers from? Just looked on awesomes website and they dont sell any hubcentric. Im wanting 10mm fromt and 15mm rear.
Are there any downsides to fitting spacers?
cheers for the help
  • -Given: 32
  • -Receive: 78
Re: wheel spacers
« Reply #11 on: February 24, 2012, 11:31:38 pm »
I've got the Forge Motorsport spacers. Ran them for a few years now with no issues whatsoever.
Offline Russ_leeds
Re: wheel spacers
« Reply #12 on: February 24, 2012, 11:32:35 pm »
where did you get them from mate?
  • -Given: 32
  • -Receive: 78
Re: wheel spacers
« Reply #13 on: February 24, 2012, 11:35:44 pm »
Offline vRS_Pagey
  • -Receive: 59
Re: wheel spacers
« Reply #14 on: February 25, 2012, 03:31:24 pm »
cheers for the help
I would also look at H&R spacers, 10 and 15mm hubcentric available from DPM Performance.  Have a look here for those and others mate - http://www.dpmperformance.co.uk/golf-5-05-09-wheel-spacers-c-1909_1945_2950.html
