Author Topic: wheel spacers  (Read 7180 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
Re: wheel spacers
« Reply #15 on: February 25, 2012, 04:36:21 pm »
I ran 8mm non-centric H&R's for a while w/stock 18"x7.5" w/225-40 rubber. I needed longer bolts for them as stock bolt length only allowed less than 2 full turns.
It was also lowered to 25" through the center of the wheel from the ground to the top of the arch. With this set-up, it only rubbed hard when cornering over bumpy roads that caused bouncing. However, no damaged was caused by this.
Offline Russ_leeds
Re: wheel spacers
« Reply #16 on: February 25, 2012, 06:22:05 pm »
cheers guys. Im running 35mm h&r springs on monza 2's, do you think ill get rubbing with 10mm front and 15 mm rear spacers then?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline Hilla
Re: wheel spacers
« Reply #17 on: February 25, 2012, 06:30:57 pm »
Has anyone fitted 20mm spacers to the rear and have a picture? Considering getting some to sit behind the OEM Pescaras, might have to change tyres but they're nearly fully worn anyhow.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
Re: wheel spacers
« Reply #18 on: February 26, 2012, 05:26:13 pm »
This is a pic of 18x8 w/225-40's, 45 offset, and 8mm spacers on the back.
This would = oem 18x7.5 w/225=40's, 48 offset(oem), and 12mm spacers on the back.
Sits at 25" from the ground to the center of the arch, and would rub if the road was bumpy in the curves.
« Last Edit: February 26, 2012, 05:30:16 pm by ROH ECHT »
Offline Hilla
Re: wheel spacers
« Reply #19 on: February 26, 2012, 07:09:27 pm »
Brilliant, thanks for that.
Looks good! :happy2:
