Author Topic: Shadow Blue: Blue Velvet or Purple Haze Pro?  (Read 1851 times)
Offline Mk5 GTian
  • -Receive: 37
« on: February 25, 2012, 05:33:53 am »
Should I use Blue Velvet or Purple Haze Pro wax for my Shadow blue MK5?
Also, when using these, what is the best polish and sealant to use please?
Should I use a coloured polish?
Thanks,
Ian
  • -Receive: 291
Re: Shadow Blue: Blue Velvet or Purple Haze Pro?
« Reply #1 on: February 25, 2012, 09:18:37 am »
VC had a similar issue: http://www.mk5golfgti.co.uk/forum/index.php/topic,40497.0.html
TBH the finish adds very little, except from the colour charging. The final effect is very subjective. I'd advocate buying the panel pots that Dodo do and do a half'n'half on the car. Polish depends on whether you're hand polishing or machine polishing. Sealant again is subjective. Liquids - look at jetseal, menzerna powerlock, poorboy's ex-p. Solids - look at FK1000P.
Neil
« Reply #2 on: February 25, 2012, 10:22:39 am »
Either, I used both of the above side by side on my blue car and couldn`t tell the difference.
I bought the panel pots as Stealthwolf says and had all 4 different waxes on, they all seemed to produce the same finish to me.
  • -Receive: 291
« Reply #3 on: February 25, 2012, 10:26:48 am »
There was a thread on DW where someone had put 3-4 layers of each wax on a small portion of the bonnet of a white van/car. You could seen the colour effect but it was subtle and took 3-4 layers to see whereas most people will apply 2.
Neil
« Reply #4 on: February 25, 2012, 11:03:32 am »
From the Juice bar, interesting . .
http://dodojuice.com/juicebar//viewtopic.php?t=2011
  • -Receive: 291
« Reply #5 on: February 25, 2012, 12:35:04 pm »
Yup that was it!
  • -Receive: 291
« Reply #6 on: February 25, 2012, 12:37:33 pm »
Okay, found the DW write up: clicky and the follow up clicky
Offline Mk5 GTian
  • -Receive: 37
« Reply #7 on: February 25, 2012, 01:29:21 pm »
Thanks Stealthwolf, I'll check  these out.
Offline al-tdi170
« Reply #8 on: March 02, 2012, 11:13:14 pm »
can i throw one in the mix, raceglaze 55 !! get a panel pot, i paid £68 for a full size.
or try chemical guys 5050 wax. i would also glaze before applying the wax, and even seal.
a glaze and sealant is good enough, something like jetseal 109, but im a massive wax fan, for that extra depth you get.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #9 on: March 03, 2012, 06:32:23 pm »
I wouldnt bother with the colour pots of DJ. It ruins all your sponge applicators and dyes everything blue in the wash.
#1493
