Author Topic: boost issues with forge dv  (Read 16311 times)
Offline SteveS
« on: May 02, 2009, 11:31:08 am »
ok, so i fitted the forge DV, however im not sure its working right...
the real boost just doesnt seem to be there, if i put my foot down theres no wheel hob/spin in 2nd like there useto and seems like a lack of power....
if i lift off the gass i dont really hear any "air" release sound as before.....
I do have a yellow spring instead of the standard green one as forge recomend it, but i cant see that causing any issues because if anything, it would keep the DV shutand thus boost would always be pushing into the engine..
i have checked the pipes, checked the orings, checked the lube... i duno??
and no i dont have no darn boost guage yet!! lol
« Last Edit: May 02, 2009, 11:33:38 am by SteveS »
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline chungster
Re: boost issues with forge dv
« Reply #1 on: May 02, 2009, 11:47:56 am »
not turned Revo to standard mode have you?????
Offline SteveS
« Reply #2 on: May 02, 2009, 11:48:41 am »
it shouldnt be no, but i will check incase, but i dont think its gonna be that
SOLD!! :(
« Reply #3 on: May 02, 2009, 11:57:06 am »
Did you disconnect the battery?
Offline SteveS
« Reply #4 on: May 02, 2009, 12:00:47 pm »
to install it? no..
« Last Edit: May 02, 2009, 12:20:31 pm by SteveS »
SOLD!! :(
Offline AwesomeSarah
« Reply #5 on: May 02, 2009, 02:51:10 pm »
http://www.forgemotorsport.co.uk/media/FSITV0108.pdf
There is a link from Forge`s site
Dont know if that will help in any way????
Not saying anything wrong about the fitting or anything , just in case it can help you
Hope you dont mind?
Sarah
Offline SteveS
« Reply #6 on: May 02, 2009, 04:12:34 pm »
thanks sarah, but thats the guide i followed. its all as should be..
just pulled the battery out, now going to reflash revo settings and see how it feels
SOLD!! :(
Offline dan.payne
« Reply #7 on: May 02, 2009, 04:13:59 pm »
to install it? no..
You sorted it steve?
Dan
GTi Edition 30 Phase 2+ :jumping:
« Reply #8 on: May 02, 2009, 04:44:16 pm »
Are your hoses to the DV orientated correctly?
Offline SteveS
« Reply #9 on: May 02, 2009, 05:18:47 pm »
well removing the batt and re-revo settings, feels maybe alittle better but still not convinced... need to get that boost guage fitted i guess.
SOLD!! :(
Offline SteveS
« Reply #10 on: May 03, 2009, 06:08:45 pm »
I think I found the problem!
I bought this off a guy from here from eBay. so already had the tubes attached, when I received it I was going to check it was the rite one but didn’t.. typical... neways
the nipple on the vacuum tap was the "accessory nipple" (imp guessing looking at the hole size) not the "solenoid reference" nipple! So I can only assume not enough air is getting though to work the thing properly?
ok, yes it’s an issue, but surely it still only leaves the DV closed so pressure is always sent to engine rather than dumped.. so I can’t see how this would mean less boost?
I don’t know how the electrics work.. but obviously the solenoid may not be seeing the right amount of air and I duno.. reducing the turbo or something :s
another issue is, i only got sent the boost gauge nipple. so i dont even have the right one! i will contact them and forge to try get it!
SOLD!! :(
Offline SteveS
« Reply #11 on: May 04, 2009, 02:26:42 pm »
 :mad:
SOLD!! :(
Offline dan.payne
« Reply #12 on: May 04, 2009, 09:45:31 pm »
Offline SteveS
« Reply #13 on: May 04, 2009, 10:23:00 pm »
well i hope its the only problem, i dont know if it would actually cause the boost issue??
SOLD!! :(
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #14 on: May 05, 2009, 10:05:42 am »
i have spare nipples  :ashamed: :laugh:
if you give forge UK a call then they are very very very helpful and nice people, they helped me get mine back up to power!  :happy2:
