Author Topic: headlight  (Read 5203 times)
dockermel
headlight
« on: March 01, 2012, 09:01:10 pm »
 :ashamed: the passenger side headlight on my car is held on with a cable tie. :ashamed: so guessing the lugs or something are broke. :sad1: can i fix this or do i need to buy a new unit??
Offline mvb12
  • -Receive: 64
Re: headlight
« Reply #1 on: March 01, 2012, 09:02:51 pm »
i think you can buy a repair kit from the stealers iirc
hugh jass
Re: headlight
« Reply #2 on: March 01, 2012, 10:11:06 pm »
 Repair kit costs £20 from dealers. Which piece do you need?
Offline mvb12
  • -Receive: 64
Re: headlight
« Reply #3 on: March 01, 2012, 10:40:45 pm »
£20 squid defo beats cable tied headlights. Brahahahahahahaha
dockermel
Re: headlight
« Reply #4 on: March 02, 2012, 07:29:13 pm »
not sure which bit i need till i take it off have read somewhere have to remove the bumper :scared: anyone live near me in ipswich can help???
Offline vRS_Pagey
  • -Receive: 59
Re: headlight
« Reply #5 on: March 03, 2012, 02:34:07 am »
It sounds like a big job, but it only took me 45 minutes to remove my bumper, fit two new headlights and then put it all back together.
dockermel
Re: headlight
« Reply #6 on: March 03, 2012, 05:29:33 pm »
 :happy2: come and do mine then :signLOL:. will have to borrow a driveway and will try the fixing kit.. anyone ever used it??
Offline vRS_Pagey
  • -Receive: 59
Re: headlight
« Reply #7 on: March 03, 2012, 06:23:38 pm »
Where are you located mate?  If you're local (unlikely) I would be more than happy to lend a hand.  :wink:
dockermel
Re: headlight
« Reply #8 on: March 04, 2012, 06:41:45 am »
ipswich :happy2:
Offline vRS_Pagey
  • -Receive: 59
Re: headlight
« Reply #9 on: March 05, 2012, 05:40:50 am »
D'oh.........
Offline bakili
Re: headlight
« Reply #10 on: March 07, 2012, 06:33:45 pm »
I am not sure if its true or not, but I looking on this http://vwts.ru/electro/g5/g5_94_eng.pdf
shows that you dont have to remove bumper to remove headlights. Bottom screw can be accessed trough bumper trim strip.
Offline vRS_Pagey
  • -Receive: 59
Re: headlight
« Reply #11 on: March 07, 2012, 06:43:27 pm »
Correct mate, but for the sake of an extra couple of minutes to completely remove the bumper, it is a lot easier and safer with it out of the way!
Offline apples12
Re: headlight
« Reply #12 on: March 07, 2012, 07:26:18 pm »
it CAN be done without removing the bumper....but i really wouldnt recommend it... you risk scratching your bumper around where the headlight is (ask me how i know!)
really is a piece of cake to remove the bumper especially with a pair of helping hands, lay down a rug/piece of carpet on the floor across the width of the car and the front just in case it does drop and so you have somewhere handy to 'lean' the bumper just incase you forgot to disconnect anything like foglights, or for when you have to disconnect your headlight washers
repairing the headlight lugs is a piece of cake, my advice is go slow with removing the material and constantly try fitting the replacement piece into the slots that are on the headlight - you dont want to remove too much.
i found a few dabs of superglue help too along with the screw and then pop it back in.
(also, if its the bottom two lugs that your replacing, make sure that the nut on the lug is out the same distance as on the original one as this will affect the alignment of the headlight etc, dont bother trying to turn the nut after you've fitted the piece to the headlight as you'll risk snapping it off again, best to use a socket and hold the plastic piece in a dish towel in your hand and tighten/loosen as necessary)
good luck!
MK6 GT TDI  - CW - LUX pack
GONE
dockermel
Re: headlight
« Reply #13 on: March 08, 2012, 08:10:45 am »
thanks for the replies..
dockermel
Re: headlight
« Reply #14 on: March 16, 2012, 07:04:17 pm »
 Right all done. Didn't need to remove the bumper just loosen it off. Found a vid on you tube.. The repair kit is a bit flimsy be surprised if it lasts long. Just plastic. Be better if it was made of aluminium .. :happy2:
