November 19, 2024, 04:24:54 am
All Things Mk5
Mk5 General Area
Strange noise when lifting off???
Topic: Strange noise when lifting off??? (Read 901 times)
Mikee
Always Involved
-Given: 0
-Receive: 2
March 02, 2012, 07:30:40 am »
Noticed a strange noise yesterday on my way to work. When I lifted off the accelerator at low revs and low speed after the initial bov sound (forge spacer) there was a really faint sound. The only way I can describe it is that it sounded like someone whispering "woo" very quietly (worst description ever)
Any one any ideas?
Just so happened my warranty ran out last week!!
Ps this is a Leon fr tfsi
nezquick
Won't Shut up.
-Given: 7
-Receive: 33
Re: Strange noise when lifting off???
Reply #1 on:
March 02, 2012, 09:40:31 am »
like this?
if so it just flutter, maybe have a play with your bov to get the settings right? maybe you have too much being vented? (im no expert)
the "woo" description is a bit difficult to pinpoint
My Build Thread:
http://www.mk5golfgti.co.uk/forum/index.php/topic,44906.msg519084.html#msg519084
nezquick
Won't Shut up.
-Given: 7
-Receive: 33
Reply #2 on:
March 02, 2012, 09:41:18 am »
my mistake, thought you had a forge bov in that case i thought it was quite normal to have a little flutter when using the spacer but i might be wrong.
My Build Thread:
Matto
Just look at my post count
-Given: 24
-Receive: 116
My Ride:
Reply #3 on:
March 02, 2012, 08:53:38 pm »
Does it only do it between 1-2k rpm? Mine does a weird noise similar to the one your describe.
GT Sport Progress Thread
My Door Lock Module Replacement DIY
Hogster
Taking part
-Given: 5
-Receive: 0
Reply #4 on:
June 09, 2012, 06:18:28 pm »
I have just noticed this noise myself, pretty sure it's only just started. Have had a stage two map on for the last 5k and it seems to be running fine
bulak
Always Involved
-Given: 2
-Receive: 0
Reply #5 on:
June 10, 2012, 01:16:04 am »
Mine makes this noise as well, happened after I put bluefin map took the map off and it's still doing it, car running normal had dyno done just to see any difference from a previous dyno no change in results. Confused myself
All Things Mk5
Mk5 General Area
