Author Topic: Best Way to ground a wire  (Read 1664 times)
Offline zenicman9
« on: March 02, 2012, 11:52:29 am »
Hi All
I am looking for the best way to ground a wire to the back of a CD player!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Best Way to ground a wire
« Reply #1 on: March 02, 2012, 12:15:43 pm »
I used a bit of metal just below the back of the CD player (basically behind the climate unit)  :happy2:
Offline zenicman9
« Reply #2 on: March 02, 2012, 12:18:00 pm »
Did you just tape it? Ive stuck it to the back with tape
Offline higher1
« Reply #3 on: March 02, 2012, 01:10:42 pm »
thats not good enough really and in a extreme case could cause heat due to being a bad earth and start a fire
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
Offline zenicman9
« Reply #4 on: March 02, 2012, 01:14:24 pm »
I know that, Was looking for some suggestions!
Offline nezquick
« Reply #5 on: March 02, 2012, 01:54:38 pm »
In my old car I would use either a thick screw, strip enough of the sleeve off to wrap it around the screw or bolt and then screw it back in clamping the wire between the piece of metal and the screw/bolt head. Alternatively I used my gas soldering pen to help seal a connection on the wire.
Offline Jaywoo-GTI
  • -Given: 38
« Reply #6 on: March 02, 2012, 02:12:24 pm »
Ring crimps behind a screw, anything else is asking for trouble. :scared:
Offline zenicman9
« Reply #7 on: March 02, 2012, 02:14:21 pm »
Its got a ring crimp on the end sorry, I have tapped the ring crimp to the back of the cd player it says mount it tro the outer casing
Offline brough74
« Reply #8 on: March 02, 2012, 02:34:40 pm »
Needs to be fixed securely be either a self tapper (screw) or a bolt to the cars metal work. Anything else is asking for trouble !
PS dont do any electrics in your house because that will end in big trouble
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
