Author Topic: Transmission / Diff whine - manual box  (Read 3389 times)
MPS
« on: March 04, 2012, 11:25:15 am »
I've noticed I've got a whine on overrun, it's more noticeable when I go around roundabouts. It's a manual box by the way. Has anyone else noticed this on their car? Do you think an gearbox oil change would help reduce the whine any?
Matt
MPS
Re: Transmission / Diff whine - manual box
« Reply #1 on: March 04, 2012, 12:30:23 pm »
Nobody?
« Reply #2 on: March 04, 2012, 12:34:19 pm »
Are you sure its the gear.box and not a wheel bearing
MPS
« Reply #3 on: March 04, 2012, 12:43:05 pm »
I thought wheel bearing was more like a rumble? It passed its MOT back in July with no issues. Diff bearing maybe? Do you think an oil change will help?
« Reply #4 on: March 04, 2012, 01:00:18 pm »
My g/f car has a wheel bearing gone but has no play in the wheel,jack the car up and sit inside will some one spins the wheel and you might hear the noise,do this with every one first
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: March 05, 2012, 07:29:34 am »
Have you got a single mass flywheel fitted?  Or your dual mass may be on the way out causing extra transmission noise.
Follow AKS tuning on Facebook
Offline john87
  • -Receive: 53
« Reply #6 on: March 05, 2012, 10:09:16 am »
I notice a whine when speeding up/slowing down in 2nd/3rd and sometimes 4th gear. Nothing worryingly loud though, and I blame it on ebing over-sensitive since I came from a clattery diesel  :laugh:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #7 on: March 11, 2012, 06:08:46 pm »
Mine has a noticeable whine in the lower gears, more noticeable when its cold and its been doing it for the last three and half years so wouldn't be overly concerned unless something has just changed.
Sepang Blue S4 BE Avant
Offline holepunch
« Reply #8 on: March 15, 2012, 07:35:11 pm »
Yep mine does it too.  I'm not concerned by it done it since I bought the car and hasnt got any worse.
Offline reflex11
« Reply #9 on: March 15, 2012, 07:54:33 pm »
say if im in 3rd and go up to like 5k ish then let go of the gas I also get this whine..  im assuming its normal?
Offline john87
  • -Receive: 53
« Reply #10 on: March 17, 2012, 09:27:54 am »
Yeah i'd say so, if you're in doubt, have the gearbox oil topped up/changed out. As long as the gears go in without crunching then I'd say all is well  :happy2:
Offline rengti
« Reply #11 on: March 17, 2012, 03:22:08 pm »
Accelerating in 1st gear seems to be most noticeable to me...but as mentioned here, i wouldn't say it's anything to worry about as long as the gears don't clunk
Offline reflex11
« Reply #12 on: March 17, 2012, 03:31:21 pm »
yes my first gear and reserve and sometimes 2nd gear is hard to get into with crunching i've noticed lately .. im putting it down to my clutch..because its knackered
