Author Topic: James GTI Ko4 2.0tfsi 401bhp - launch control?  (Read 135666 times)
Offline james
Re: James GTI with K04 (re-remapped)
« Reply #225 on: October 10, 2012, 03:51:56 pm »
takes 15 min :happy2:
it is not like the rs4 valve  :mad:
h4rdy
« Reply #226 on: October 10, 2012, 03:57:54 pm »
yep, the s3 g247 made my engine run lean.
It is do with the voltage they signal on,  bwa has one point and it seems the s3 has to points.
Tips.
Just change it on your drive! only took me 1.5 days on my own, really easily job  :drinking:
James, I can't believe this. I have had a lean problem for ages and spent loads trying to sort. I changed my G247 about a year ago due to, turns out in the end, a map problem.
It was given to me, I have my original Jesus I really hope it is I just bought new injectors!
Can you remember your fault code?
Lean off idle by any chance?
Offline james
« Reply #227 on: October 10, 2012, 04:03:26 pm »
Yea was something like that, took me a little while to work out just started playing with the sensors and found this one to be the problem.
When i looked into it, i found out they are different on the ed30/s3/r have two points of signal and the axx/bwa have one.  Once I installed my old one problem solved.
why did you change it??
You can also correct it in the map.
« Last Edit: October 10, 2012, 04:05:51 pm by james »
Offline james
« Reply #228 on: October 20, 2012, 04:40:52 pm »
Well I popped to r-tech for a couple of days for some testing to find out really what this turbo can do with WMI!
We started off by setting up launch control at 4k but it was abit of an epic fail, the car has way too much power and just sits there!  So I asked nick to have a look into limiting the power in 1&2nd to see  if we could get a good launch!  (still in testing)
The next fun part was seeing what we could get out of the old girl!   The car was producing good power 380hp/400ftlb but the turbo was tailing off so much at the top end!  (like normal)  So went about adjusting the actuator on the turbo .  We found it nearly made 50hp on the stop end! but you lose it down low but that suites me.
The next problem was we were getting a dip at 5800rpm then it would pick back up at 6200. Logged the LPFP and it was dropping to 3.9bar :(   So I got the latest revision from TPS “1K0 919 051 DB” + new fuel filter it was then holding 4.2 bar  so it is better but will need an inline fuel pump!!
Also just a fyi  the car made an extra 12hp and 10bhp just buy installing a new fuel pump and filter!  (might be something to look into?)
In the end we left the car with some more testing required, but this was the end power result!  Good show for a standard k04 and WMI!!
Must thank nick for a epic car :driver:
Re: James GTI Ko4 2.0tfsi 401bhp 447lbft ;)
« Reply #229 on: October 20, 2012, 05:26:36 pm »
You still coming to JKM next Saturday, James?
h4rdy
« Reply #230 on: October 20, 2012, 05:29:07 pm »
I hope so I need to see it :driver:
Offline james
« Reply #231 on: October 21, 2012, 10:14:57 pm »
Yea I'm still coming.  :happy2:
Just might get a little dip on the rr due to lpfp.
Offline kiddfrost
« Reply #232 on: October 22, 2012, 09:08:21 pm »
Well gotta say that 400bhp from a k04 is impressive.  You've gotta be doing the wrong side of half a litre a minute on the water meth at 400bhp surely?
Looking forward to seeing it on JKM's rollers..
Offline Obese
« Reply #233 on: October 22, 2012, 09:23:22 pm »
I have only just read this thread and your car is a very simular spec to mine, i am definately thinking a trip to rtec is in order :happy2:
love it :happy2:
Offline james
« Reply #234 on: October 23, 2012, 12:07:30 pm »
I dont use much meth at all,   all day on the rr i only used 2L      i only use it from 20 psi
on my bwa i used loads cdl does not need so much.
Obese  - You should go see him! fantastic service!
Offline james
« Reply #235 on: October 23, 2012, 05:23:05 pm »
Anyone else got launch control for their manual GTIs?
Wondering how you find it,    i have tried it at 3k & 4k   but seems to bog down or spin lol.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #236 on: October 23, 2012, 05:37:19 pm »
I have just had it fitted, not tried it yet though  :smiley:
Over the top mod list ;o)
Offline nezquick
« Reply #237 on: October 23, 2012, 05:48:31 pm »
what kit is that with? omex or wotbox? or did you have it mapped in somehow?
Re: James GTI Ko4 2.0tfsi 401bhp - launch control?
« Reply #238 on: October 23, 2012, 05:52:23 pm »
The race logic traction control / launch looks very trick  :innocent:
Offline james
« Reply #239 on: October 23, 2012, 05:57:28 pm »
it is in the remap,  no funky tools needed.
just bounces of 3k in natural when your foot is to the floor.
Just trying to get the hang of it lol
