Author Topic: James GTI Ko4 2.0tfsi 401bhp - launch control?  (Read 159323 times)
Offline rtechniki
  • -Receive: 27
Re: Re: Re: James GTI with K04 (re-remapped)
« Reply #255 on: October 25, 2012, 07:18:48 pm »
yep, the s3 g247 made my engine run lean.
It is do with the voltage they signal on,  bwa has one point and it seems the s3 has to points.
Tips.
Just change it on your drive! only took me 1.5 days on my own, really easily job  :drinking:
We found the k03 ecus run a 140bar rail pressure sensor with a 2 point linear 0-5v scale in the software, and the k04 ecus run a 200bar sensor with a 3 point 0-5v scale to give better reading at higher rail demands.   Since finding this out on james CDL I have now produced a base map to run the k04 sensors on the k03 sw.
this sounds very interesting as I am in the middle of dropping a CDL Engine in to my mk5 so it would be benifcial running the k04 rail pressure sensor rather than the k03 sensor? 8)8)
Unless you use the ECU from the CDL it won't work, H4RDY has made a topic abut this.
The AXX software is the 2 point reference rail sensor mapping   0.5v = 0 MPa / 4.5v =14 MPa
The BWA software is a 3 point reference rail sensor mapping     0.5v = 0 MPa / 2.5v = 7 MPa / 4.5v = 14 MPa
The CDL BWJ is also a 3 point reference rail sensor mapping     0.5v = 0 MPa / 2.5v = 10 MPa / 4.5v = 20 MPa
In theory we can change the 4.5v point to 20 MPa in the AXX mapping it will work fine as its just linear voltage to work with the CDL sensors.  Its not an issues with the BWA software we can just use 0.5v = 0 MPa / 2.5v = 10 MPa / 4.5v = 20 MPa from the CDL mapping.
Anyone else know what other sensors differ across the AXX BWA CDL and BWJ engines?  I cant look in to the software and see what can be used and what needs attention in the SW.
Nick Gower
R-Tech Performance Tuning
Hinckley 01455 617233
Bespoke ECU Software for 1.8T & 2.0TFSI
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: James GTI Ko4 2.0tfsi 401bhp - launch control?
« Reply #256 on: October 27, 2012, 05:50:20 pm »
James - seriously impressed with yours today  :laugh:
Cheers for the ride  :happy2:
That 1st gear limiter is comical though  :grin:
Get that graph up on here  :party:
Graeme
Offline andy redz
« Reply #257 on: October 28, 2012, 01:47:08 pm »
 :popcornsoda: nice build ..
Offline james
« Reply #258 on: November 01, 2012, 03:05:23 pm »
here is my jkm result
It will be going AWD  :innocent:
GrayMK5GTI  - Yea it is good fun to drive lol.
Offline vRSAlex
  • -Receive: 253
« Reply #259 on: November 01, 2012, 05:51:39 pm »
James, what boost are you peaking and holding at?
Follow AKS tuning on Facebook
Offline james
« Reply #260 on: November 02, 2012, 11:20:34 pm »
spikes to 30 and holds around 19/20 at redline
Offline vRSAlex
  • -Receive: 253
« Reply #261 on: November 03, 2012, 08:26:14 am »
That's after the actuator has been tightened up?
h4rdy
« Reply #262 on: November 03, 2012, 10:46:14 am »
I believe so Alex.
Offline james
« Reply #263 on: November 03, 2012, 04:31:17 pm »
that is correct  :happy2:
problem is with this turbo, if you set the duty to 70% top end you will put the same power even if you set it to 100% as it blows the westgate open.
Would be intrested to see what would happen if you installed a stronger spring.
« Reply #264 on: November 03, 2012, 04:39:40 pm »
Using the forge actuator or oem?
h4rdy
« Reply #265 on: November 03, 2012, 04:40:09 pm »
I've been thinking of a forge actuator with a stronger spring?
Offline Statller-Stevo
« Reply #266 on: November 03, 2012, 04:57:00 pm »
Got a forge actuator if you want it, had it on my last hybrid Fuxxin horrible!
Gave Massive boost spike the but to be fair we tensioned it a wee bit  :grin: made 450ft lb on spike but tailed off like a bitch after was a quick car though tbh!
Offline james
« Reply #267 on: November 03, 2012, 05:03:43 pm »
yea i get 450ftlb but like you say it tails off fast like you can see in my rr
i cant be arsed to take the turbo out to change it, would rather just stick a bigger turbo on if i was going to do that  :signLOL:
« Reply #268 on: November 03, 2012, 05:12:14 pm »
U don't need to remove the blower to fit the actuator but it is a PITA to get too!!! Reach for the TCP after etc.
TBH James you don't need it at all Your doing far too well as is !!  :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #269 on: November 03, 2012, 11:48:22 pm »
How much of an improvment would this make? ^^^^^
Silver is the way !
