Author Topic: IPad event today :)  (Read 24129 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: IPad event today :)
« Reply #150 on: March 22, 2012, 09:37:02 pm »
Do you not use auto brightness? I find that helps a lot especially if I'm reading a book in bed etc
The only thing that does bug me is it doesn't work like they used to. It will go brighter on its own but it won't dim unless you switch it to standby and back on again. I preferred it when it would dim/brighten as needed. The iPhone is the same these days.
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #151 on: March 22, 2012, 09:52:54 pm »
Yep, I use auto brightness, but I've never found it does much.
  • -Given: 32
  • -Receive: 78
« Reply #152 on: March 22, 2012, 09:53:28 pm »
Another thing, it takes bloody ages to charge!
Offline Janner_Sy
  • -Receive: 113
« Reply #153 on: March 22, 2012, 10:00:54 pm »
The battery monitor on my tablet shows 87% of the battery life is dedicated to the screen
« Reply #154 on: March 22, 2012, 10:06:05 pm »
The new one does take longer to charge should last longer though  :smiley:
Saintsteve
« Reply #155 on: March 23, 2012, 07:14:12 am »
No problems either on my 3 either.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #156 on: March 23, 2012, 08:52:02 am »
Make sure you only use the new charger and cables that came with your iPad. The old cables and iPhone chargers don't work on the new iPad for some reason.
#1493
  • -Given: 32
  • -Receive: 78
« Reply #157 on: March 23, 2012, 09:29:37 am »
Seems I'm not alone with the battery drain issues.
http://forums.macrumors.com/showthread.php?t=1346241
And for those of you saying the battery life is improved, I wouldn't listen too much to Apples claimed battery life as this doesn't take into consideration how much power a certain app uses. Normal web browsing for example is supposed to drain more battery in the new iPad than the iPad 2.
« Reply #158 on: March 23, 2012, 09:32:28 am »
...its worth noting too that for ipad newbies when youre done with an app, double click the center button and shut it down properly because otherwise you can end up with all sorts still running
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #159 on: March 23, 2012, 09:50:44 am »
Mine work's perfectly fine  :confused:
  • -Given: 32
  • -Receive: 78
« Reply #160 on: March 23, 2012, 09:53:39 am »
Lol, are you sure you've got one Carl?
They will work, but they'll also take ages to charge it. Even Apple have stated that.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #161 on: March 23, 2012, 09:54:31 am »
I don't seem to have a problem. I have used my iPad pretty much all day  a few times since i got it (circa 8-9 hours) web browsing, listening to music on it, playing the odd game, reading a book, watching the odd youtube vid etc and the lowest i have got on the battery is 28%.
What apps are you using?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #162 on: March 23, 2012, 09:57:23 am »
Why would i lie about it? :confused: Would you like to see a picture of it and my order details from Apple?
Which is my point. They do work. Deako said they don't when they do. I charge mine up over night  when it is required so i never notice any problems with charging.
  • -Given: 32
  • -Receive: 78
« Reply #163 on: March 23, 2012, 10:01:28 am »
I'm only joking mate :wink:
When you said fine I assumed you meant there was no difference. To clarify, yes the old chargers work, but they take an awfully long time to reach full battery.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #164 on: March 23, 2012, 10:04:40 am »
Yup i read those reports. It even takes longer to charge with it's own charger. Apparently it can take upto an hour after the iPad reports 100% to reach full charge according to what i read on iClarified the other day.
http://www.iclarified.com/entry/index.php?enid=20864
Maybe that is where some people are having a problem. As i said mine get's done overnight so it is probably sat on 100% for at least a couple of hours and i am using a spare iPhone charger to charge it with.
One thing i have noticed is that the 2m cables don't work with it properly for some reason. Sometimes they do and sometimes they don't. It's not the cable as it works fine with my 4S
