Author Topic: Near Side Outer CV Boot Replacement  (Read 3061 times)
Offline ianv5
« on: March 08, 2012, 12:36:23 pm »
As above is it a job I could do myself or does it need to be done at a garage?
Offline vRSAlex
  • -Receive: 253
Re: Near Side Outer CV Boot Replacement
« Reply #1 on: March 09, 2012, 07:13:49 am »
As long as you have the correct tools and a vice then you should be able to do it.
You really need an impact gun, multi spline sockets, cv clip tool and a big copper hammer.
Follow AKS tuning on Facebook
Offline s2martyn
« Reply #2 on: March 10, 2012, 08:45:08 pm »
no,no,no..the shaft doesnt need removing from the car,easyly done with the right tools(if your a technician)
Offline ianv5
« Reply #3 on: March 12, 2012, 12:37:59 pm »
So what tools will I need?
I had the front wheel off yesterday and from my understanding I need to remove brake caliper and front disc to get at the outer CV boot?
Anything else?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: March 12, 2012, 12:56:33 pm »
Despite contrary advice above when I did one I removed the driveshaft.  Not much extra work and much easier to do on the bench etc.
Getting the CV joint off was quite hard but a Master Tech gave me the advice of using a driveshaft bolt driven right down the centre, preferably with a windy gun (which I guess makes it easier if you leave the shaft on the car) to push the CV joint off.
Stu...
Saintsteve
« Reply #5 on: March 12, 2012, 02:29:33 pm »
Oh yeah.. Good luck  :signLOL:
