Author Topic: Wipers not working  (Read 22563 times)
Offline Phil Miller
  • -Given: 86
Wipers not working
« on: March 09, 2012, 10:48:47 pm »
Hi all, quick question, my front wipers dont work, front washers do and rear wash wipe does, ive been thro the fuses under the bonnet all seem fine, if the bonnet catch had failed (it shuts properly) do the front washers still work?
Offline Little_Dave
Re: Wipers not working
« Reply #1 on: March 10, 2012, 12:08:35 am »
Best way to check if its the bonnet sensor is to disconnect it and your wipers will work again if its the sensor  :happy2: it's located next to the right hand side headlight cluster just follow the cable from the catch back along to find it and unplug
Dave
Offline Phil Miller
  • -Given: 86
« Reply #2 on: March 10, 2012, 12:24:29 am »
Dave
Ideal thank you Dave, atleast the wife can use the car tomorrow while i wait till monday for TPS to send one out, will go try that now  :happy2:
Offline Phil Miller
  • -Given: 86
« Reply #3 on: March 10, 2012, 12:32:43 am »
Just been out and disconnected it and they still dont work :sad1:
any ideas?
Offline Horatio
  • -Receive: 39
« Reply #4 on: March 10, 2012, 02:03:08 am »
Have you tried tightening the wiper bolts. Had a new windscreen fitted this week. After autoglass techy fitted it he tried testing the wipers and they didnt work?  :surprised: I pointed out that they werent bolted on. Worked fine after after they were bolted up.
Offline s2martyn
« Reply #5 on: March 10, 2012, 06:45:38 pm »
fuse??under bonnet at side of battery,i think its a 25 amp that goes the wrong way to the others,or maybe bonnet latch switch,the multiplug wires need to be joined so it thinks its shut not pulled apart..you can also check on vagcom if you have that
Offline Phil Miller
  • -Given: 86
« Reply #6 on: March 10, 2012, 07:16:18 pm »
Right here is what we have, a new bonnet catch has been fitted and its still the same :confused:, ive been thro every fuse under the bonnet and in the dash and they are all fine :confused: i plugged into VCDS and got the following that wont erase
                Address 09: Cent. Elect.       Labels: 3C0-937-049-23-H.LBL
Control Module Part Number: 3C0 937 049 AE    HW: 3C0 937 049 AE
  Component and/or Version: Bordnetz-SG     H52 2002
           Software Coding: E48B8F0600042332021400001400000000017B075C0001
            Work Shop Code: WSC 00000 785 00200
           Additional Info: Fehler Lin-Slave 01    Fehler Lin-Slave 02
                      VCID: 6CD3C083361B
2 Faults Found:
02071 - Local Databus
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 235666 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00153 - Windshield Wiper Motor;  Driver Side (V216)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 235666 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 12.00 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
I then googled the fault code and found this
00153 - Windshield Wiper Motor; Driver Side (V216): No Signal/Communication
Possible Symptoms
Front Wiper not functioning
Possible Causes
Fuse(s) faulty
Engine Hood Contact Switch faulty
Wiring/Connectors from/to Windshield Wiper Motor Driver Side (V216) faulty
Possible Solutions
Check/Replace fuse(s)
Check/Replace Engine Hood Contact Switch
See Measuring Value Blocks (MVB)
Check/Repair Wiring/Connectors from/to Windshield Wiper Motor Driver Side (V216)
Check/Replace Windshield Wiper Motor Driver Side (V216)
Special Notes
When found in VW Golf (1K): Central Electronics (in Combination with 02071), check for Aftermarket Xenon installation.
Aftermarket Xenon installations may destroy the Wiper Electronics, installations like this are usually illegal and use H7 Bulb mounts for the Xenon bulbs.
Ive disconnected my HIDs (that have been fitted for 2 years fault free) still no different
i need the car so the OH can take the kids to a party tomorrow (i left hers at work on friday as im on call and have the spec) so im not favour of the month at thye mo, please help
Offline s2martyn
« Reply #7 on: March 12, 2012, 11:17:28 am »
if there is a missing can bus message to the cecm its either the wiper motor or cecm thats dead,maybe due to the hid current feedback to the controller??????
Offline Phil Miller
  • -Given: 86
« Reply #8 on: March 12, 2012, 07:32:54 pm »
I had the same line of thought so refitted my old lowline CECM but it made no difference at all, i called TPS today and a new motor is £105 +vat one is coming out tomorrow :sad1:
My HIDs are being removed and will never go near my golf again
Thanks for posting mate :happy2:
Offline Phil Miller
  • -Given: 86
« Reply #9 on: March 14, 2012, 08:06:49 pm »
All sorted, it was the wiper motor, was quoted £105+vat from TPS arrived today and it was £82.49+vat given a massive discount of 28% so im happy with that, the HIDs have gone in the bin so xenons is my next step  :laugh:
« Reply #10 on: March 14, 2012, 08:13:09 pm »
good to see you got it sorted :happy2:
