Author Topic: HOW TO:- Fit a Skoda 1Z0 035 729B bluetooth kit (lots of pictures)  (Read 53191 times)
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: HOW TO:- Fit a Skoda 1Z0 035 729B bluetooth kit (lots of pictures)
« Reply #30 on: April 12, 2012, 10:03:01 pm »
Cheers stu, I saw a picture in another thread where the cover was black plastic and wasn't sure.
Ordered cover, clips etc today, so will be fitting next week. This thread has and will be a massive help when it comes to fitting.
« Last Edit: April 12, 2012, 11:55:18 pm by jason_rmh »
VCDS (Preston, Lancashire)
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #31 on: April 12, 2012, 10:26:46 pm »
Have you read this -
http://octavia-vrs.com/cms/content/integrated-bluetooth
There are slightly better ways to do things since I wrote this guide but you'll get the general idea.
Stu...
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
5N0 035 730 A,B or C are good
Does anyone know if the 5n0 c version will work on the mk5 red highliine?
I'm not sure if c version is white mfd only.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
I read in another thread, it will work with red mfd as long as its high line so you can enter the code for the phone.
http://www.mk5golfgti.co.uk/forum/index.php?topic=44631.0
Offline baz_4
« Reply #34 on: May 09, 2012, 07:13:01 pm »
I've been trying to research into the best bluetooth for my car but have no idea what to go for.
I have a 2010 Scirocco R with RNS510 factory fitted with the white dot highline display, it has voice recognition so i'm assuming the mic is in place?!
I want a bluetooth kit that is compatible with iphone and can play bluetooth audio. Any ideas on how to get a bluetooth box which ticks all the boxes? (looking below I dont think you can have it all?)
Anyways, if anyone has any advice or can point me in the direction of a good kit let me know.
Barry
Phone button works
Do you mean the star button Eddie?
Skoda 729B = No working phone button
7P6 & 5N0 = Working phone button accept and end calls
Star button = Voice control
Offline stu_no_1
« Reply #35 on: June 10, 2012, 10:34:52 am »
im confused with this whole highline working menu button thing my car is an 06 plate dsg with highline and mfsw i have a button i press to change from trip computer to audio to setting menu is this the working menu button people are talking about or will i have issues if i fit the 5no kit?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #36 on: June 10, 2012, 11:16:08 am »
if your menu button works then you will be ok :happy2:
I didn't have a working menu button with my old cluster and I would be trapped in the phone menu
Cluster and Key coding
Location Great Yarmouth
Offline stu_no_1
« Reply #37 on: June 10, 2012, 01:52:43 pm »
Did the really early cars have different steering wheel buttons or something or is it if you don't have mfsw you didn't have a menu button
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #38 on: June 10, 2012, 02:31:06 pm »
early cars operated the menu by the stalk
so any highline 970 or 971 didn't support the menu button
If you fit a mk6 wheel the up button would allow you to access the menu.
I fitted a Mk6 wheel into a car that had a 972 cluster and that also didn't work with the 5N0 kit and got stuck in the phone menu. (although with a mk5 wheel it was ok)
I now have a 974 cluster which only supports the menu button. and it works well with my mk6 wheel
Offline stu_no_1
« Reply #39 on: June 10, 2012, 05:13:53 pm »
Can you fit Bluetooth without rns 510 or would this be something that could only be fitted after rns 510
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #40 on: June 10, 2012, 05:15:29 pm »
depends on which phone kit you fit
Offline stu_no_1
« Reply #41 on: June 10, 2012, 06:24:51 pm »
I would be looking ti have one that would work with rns 510 when I eventually fit it but if that's not possible I'll just wait till I get rns and fit them both at the same time
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #42 on: August 12, 2012, 05:51:20 pm »
Little resurrection as I used this how to guide today to get success - the only difference is that I placed the 5k0 interface module under the ashtray as someone else suggested - snug fit but made the loom an easy drop from the headunit to the interface  :happy2:
I have some pics if anyone needs them  :driver:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #43 on: August 14, 2012, 10:21:29 am »
Great guide, used this when doing mine
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
+1
