Author Topic: HOW TO:- Fit a Skoda 1Z0 035 729B bluetooth kit (lots of pictures)  (Read 53153 times)
Offline bakili
Re: HOW TO:- Fit a Skoda 1Z0 035 729B bluetooth kit (lots of pictures)
« Reply #45 on: August 15, 2012, 07:58:10 pm »
Anyone got part number for black clips, which fits in 2 holes under seat?
My 5N0 is in post, thanks to Eddie  :notworthy:
Did some research and looks like latest HTC phones may work with 5N0 kit.
Phone needs to be rooted, install 2 apps rsap install (free) and rsap (free to try, £7.50 to buy). Will report back if successful pairing HTC ONE
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
I tried the rsap apps with 5no and my rooted HTC desire without success. Was only trial version though.
I have the part number, will dig it out.
Jas
VCDS (Preston, Lancashire)
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Offline bakili
« Reply #48 on: August 16, 2012, 05:18:07 am »
Do I need Bluetooth aerial 8P0 035 503 E (8P0035503E) – for 5N0 035 730B  kit?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re: Re: HOW TO:- Fit a Skoda 1Z0 035 729B bluetooth kit (lots of pictures)
« Reply #49 on: August 16, 2012, 06:23:40 am »
Not sure on the part no but yes, the 5n0 kit needs a separate aerial.
Jas
Offline bakili
« Reply #50 on: August 16, 2012, 06:30:19 pm »
Done  :star:
followed this guide, but did install under passenger seat, a lot easier  :drinking:
Special thanks to Eddie for supplying kit :notworthy:
Can confirm HTC One V rooted with rSAP app working  :happy2:
Offline callis
« Reply #51 on: November 19, 2013, 08:15:11 am »
Great right up many thanks.
I am looking to retrofit bluetooth and need some advice on which one to get for my golf.
I have an 05 gti, RCD510,  and the older clocks.
Which one would be best but not stupid expensive. Was thinking the 7P6 kit?
Daron
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #52 on: November 19, 2013, 11:40:33 am »
Daron
I had a 5K0 (same as 7P6) kit into 55 plate with rcd510 and it was great so would highly recommend
Offline callis
« Reply #53 on: November 19, 2013, 06:20:35 pm »
Brookesb32
Thanks for the info, do you have the full part number? I have seen a 5K0 on Ebay ( 5K0 035 730 D ) however it says only works with the white dot matrix display.
As mine is an older MFD i guessing i will need an older bluetooth system?
Daron
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #54 on: November 21, 2013, 06:34:38 pm »
Brookesb32
Daron
Hi Daron
I had that exact module in my mk5 and I didn't have highline. Works off the rcd510 perfectly. I also have that same module in my mk6
Hope that helps
Simon
Offline callis
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #56 on: November 21, 2013, 09:02:46 pm »
I have a feeling that the 1k8 is the one that only works with white highline - but Eddie_nl will be able to confirm.
He can also most probably source you the wiring harness for around the £50-60 mark, so of you can get a module for under £100 (I paid about £60 I think for my last one) then you would be much cheaper than the first link above
Offline callis
« Reply #57 on: November 21, 2013, 09:47:07 pm »
Ah many thanks.
Last question and really do feel like a noobe here, but i guessing that i need a Bluetooth Aerial as well to plug into the module?
cheers
Daron
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #58 on: November 22, 2013, 11:16:34 pm »
Ah many thanks.
cheers
Daron
Nothing wrong with that question, we are all noobs at things. You don't need an aerial no, as it uses the phone for signal. All you need is the module and the loom - which also includes the mic
Offline callis
« Reply #59 on: November 24, 2013, 10:01:07 am »
cheers buddy  :drinking:
