Author Topic: HOW TO:- Fit a Skoda 1Z0 035 729B bluetooth kit (lots of pictures)  (Read 53151 times)
Offline K9
  • VW LifeStyle
Re: HOW TO:- Fit a Skoda 1Z0 035 729B bluetooth kit (lots of pictures)
« Reply #60 on: December 06, 2014, 05:50:36 pm »
bump will take this up again.
what BT do i need for my RCD510? only got Midline clocks. want it just to work so i can play music from spotify from galaxy s5
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #61 on: December 06, 2014, 08:33:08 pm »
I think i asked similar questions earlier in the thread when I was looking to do the same thing a while ago.
Heres the info i collected at the time to help.
The 7P6 kit. Also known as the 9W7.
7P6 = (doesn't display in Highline) but works with RCD510 + RNS510, plays audio from your phone, Phone button works on mfsw and works with all phones.
Note: does display in highline if you have the polar fis advanced module :)
7P6 035 730 A/B/C/D etc
For music streaming you need a module that supports A2DP (Advanced Audio Distribution Profile, bluetooth 2.0)
7P6 035 730 B - HFP and A2DP
7P6 035 730 C - HFP and A2DP, text to speech and voice recognition
7P6 035 730 D - HFP and A2DP, text to speech and voice recognition, supports external phone cradle
HFP = Hands Free Profile (Phone still logged in, Vehicle/Bluetooth Module acts mostly as Headset)
I have the 7P6 in my car, and has worked with all my android phones.
And finally, see here for a low down on all the bluetooth modules and capabilities :)
http://wiki.ross-tech.com/wiki/index.php/Telephone_Retrofitting
Hope this helps.
Jas
VCDS (Preston, Lancashire)
Offline K9
  • VW LifeStyle
« Reply #62 on: December 06, 2014, 08:34:56 pm »
Hope this helps.
Jas
@jason_rmh PM'd you
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #63 on: December 06, 2014, 08:35:39 pm »
look at members rides. loads of people have covered this
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline K9
  • VW LifeStyle
« Reply #64 on: December 06, 2014, 08:36:54 pm »
ok will try to see if i find someone who writed about this  :happy2:
Offline KieranR
« Reply #65 on: December 30, 2014, 01:55:18 pm »
Thanks for this guide OP. Just followed it completely and installed a 7p6 kit in my 2008 car.  It didnt even need any coding.  Worked straight away.
« Last Edit: December 30, 2014, 03:50:52 pm by KieranR »
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #66 on: December 30, 2014, 09:03:30 pm »
Hi Kieran, which model did you install I.e. what was the last letter a,b,c or was it one of the later spec ones?
Thanks Rob
Black Ed30
Offline KieranR
« Reply #67 on: December 30, 2014, 09:28:42 pm »
Thanks Rob
Hi Rob. It had the letter M at the end and began with 7p6. Got it from a seller in UK on eBay for 90 pound. Bought the mic from some one on here for 10 pound and loom from carsystems.pl separate then. Worked our pretty reasonable all together. Really impressed with it. Have Bluetooth streaming of music and phone book etc on headunit
Offline Owencash
« Reply #68 on: March 01, 2015, 04:38:35 pm »
hi guys,
i have just fitted an Rns 510 into my edition 30, it has red highline display and has MFSW which i can scroll through trip, audio and settings with, i have an iPhone 5s, i want to be able to stream music and obviously make calls !
which would be the best option for me to purchase and install ?
Offline Owencash
« Reply #69 on: March 01, 2015, 04:43:07 pm »
hi guys,
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #70 on: March 01, 2015, 05:10:56 pm »
7p6 would be the one to go for, however you wont see the phone options in the highline menu, unless you get a 100 quid adapter
http://www.carsystems.pl/fis-link-can-box-converter-for-red-dot-matrix-fis-and-new-bt-modules,id687.html
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #71 on: March 01, 2015, 05:22:39 pm »
Or polar fis advanced
Jas
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #72 on: March 20, 2015, 05:57:23 pm »
Also appreciating this post by Smokey, I followed it pretty much to a T only cutting one or two corners whilst routing microphone lead.
Black Ed30
Offline Greek_GolfV
  • Newbie
« Reply #73 on: April 25, 2022, 05:37:35 pm »
Hi Guys! I'm new to the forum and recently bought a Golf V Gti .... And apparently I will be with you for a long time!
The car is equipped with a factory Bluetooth kit but it is old generation and I can not connect my mobile phone!
It is a model 2008 GTI luxury pack with highline cluster and MFSW with the new buttons! I recently put an RCD510 on it and now I want to put the BT module on it to connect my cell phone! All of the above are factory except for the rcd 510 ... It also has a factory antenna for bluetooth!
Can you help me buy the right spare part? Thanks in advance! Greetings from beautiful Greece!
