« Reply #7 on: March 13, 2012, 06:12:00 pm »
There are several companies that do it on a one off basis - Google will be your friend.
I'm not sure what prices will be like, my company charges $60 USD per analysis but that's on a bulk scale.
Identifying Fuel Dilution could be costly if it's not significant. It's referred to as a Flash Point Test, normally using the Pensky-Martens Closed Cup which is a bit more of an analogue result (either it is or it isn't at a specific value).
If you wanted to get an idea of the volume or percentage of fuel in the oil you need to either do several tests with the Pensky-Martens at varying temperatures until you find the level or use a much more expensive method such as Gas Chromatography.
Viscosity will also give an indication of fuel dilution in engine oil.
Stu...
