Author Topic: First problem with my GTI [SOLVED - Video)  (Read 8914 times)
Offline 56OctyVRS
  • -Receive: 72
Re: First problem with my GTI
« Reply #30 on: April 12, 2012, 09:04:45 pm »
you have PM :happy2:
Offline Moz
« Reply #31 on: April 12, 2012, 09:50:21 pm »
Sweet, see you Sat.
Cheaper than the 1k I was being quoted!
Offline blackmagic
« Reply #32 on: April 13, 2012, 04:25:17 am »
Hope you have your problem solved . I've had a similar bizarre isuue for a while. I'm stage 2+ mind but one day I'll go for a spin and the car will be epic absolutely fantastic big smile etc. then if I go for a drive very next day there is something missing still very quick but just something not quick right 1/2 sec more lag, lower top end power etc. I've never go to bottom of it. Never any fault codes recently changed dv, n75, plugs, coilpacks. Anyone any ideas? I know I need to get a data logging session done but sods law it will be on a fine day.
Black GTI K03 Revo Stage 2+,
Offline 56OctyVRS
  • -Receive: 72
« Reply #33 on: April 13, 2012, 07:20:04 am »
Have you tried logging  your maf sensor readings as that may be on its way out.
Offline Moz
« Reply #34 on: April 14, 2012, 08:49:25 pm »
Massive thanks today fella, helped me out loads. Going to have a go fitting tomorrow pending weather.
Offline 56OctyVRS
  • -Receive: 72
« Reply #35 on: April 15, 2012, 12:30:02 am »
No worries mate :happy2:
I hope you get it fitted okay and your little one is feeling better.
Im hoping for nice weather as im off to the BTCC at Donnington Park.
Offline Moz
« Reply #36 on: April 15, 2012, 11:07:11 am »
Ah nice been there a few times, last time was a couple of years ago with a VIP for Team RAC was very enjoyable.
Jason Plato just edged it against Carl Turkington (Team RAC)
Weather was lovely.
Offline 56OctyVRS
  • -Receive: 72
« Reply #37 on: April 15, 2012, 01:29:01 pm »
Its a bit chilly here but its all good :happy2:
Offline Moz
« Reply #38 on: April 15, 2012, 01:29:40 pm »
Great stuff, I ran out of time this morning and have United at 4pm so think I'm giving it a miss today!
Offline Moz
« Reply #39 on: May 02, 2012, 04:54:51 pm »
Well finally got round to getting a garage to fit the part I got off VRS, and sadly it didn't fit they garage told me, apparently this has a small bend after the flex and my GTI has quite a large bend making it incompatible, however the same diameter.
I am however getting him to weld them up together with a sleeve over it that should do the trick, so not a huge great deal.
be glad to get this noise sorted!!
Offline Moz
« Reply #40 on: May 16, 2012, 08:37:52 pm »
Ok so had a local place fit the new downpipe with pre cat removed and if anything it;'s now worse.
The sound is evident on idle, it sounds very metallic, and then every time I release the revs it happens and now it's really loud.
Could it be the main cat its self? Sounds like loose metal mesh that's being ripped around every time I let off my revs.
Going to take it back to the garage on Monday to see what they say, but I'm now thinking turbo or cat etc? Performance is down, takes a while to spool etc, but I;ve bought a new diverter valve just in case also.
« Reply #41 on: May 16, 2012, 08:48:32 pm »
....One way to check the cat is to fist the box [that doesn't sound quite right!] - I'll rephrase that: Hit the cat enclosure with the side of your fist and listen for any rattling inside. Obviously wait until it's cold!
It shouldn't rattle.
« Last Edit: May 16, 2012, 08:55:50 pm by RedRobin »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #42 on: May 16, 2012, 08:52:34 pm »
I get a little more resonance (or loose mesh as you described it) with my pre-cat removed. Garage checked the system for leaks and put the sound down to the pre-cat being removed.
Offline Moz
« Reply #43 on: May 16, 2012, 09:19:23 pm »
Ok cheers I'll have a punch in the AM. See. How it goes on.
Offline Moz
« Reply #44 on: May 16, 2012, 09:21:20 pm »
Whilst with pre cat removed it does sound throaty, This is defo a fault problem.
