Author Topic: Slight knocking from front at low speed  (Read 10633 times)
Offline Little_Dave
Re: Slight knocking from front at low speed
« Reply #30 on: March 25, 2012, 07:59:25 pm »
Doubting its my front ARB bushes now as i recall it was more of a squeeking noise when the rear needed lubing properly and it was constant all the time over the slightest bump  :confused: back to the drawing doard me thinks  :stupid:
Dave
Offline Phil Miller
  • -Given: 86
« Reply #31 on: April 22, 2012, 01:28:23 pm »
does anyone have the part numbers for the subframe bolt stuff, gonna try this asap
« Reply #32 on: April 22, 2012, 01:37:54 pm »
7M3499349A  - Plate x 2
N90823501 - Bolt x 2
Offline Phil Miller
  • -Given: 86
« Reply #33 on: April 22, 2012, 01:48:25 pm »
Thank you Mike
« Reply #34 on: April 22, 2012, 02:14:00 pm »
Offline tomolambo
  • points mean prizes
« Reply #35 on: May 15, 2012, 10:17:49 pm »
i also have a slight knock from the from only seems to be when i take up drive at low speed forward and backwards
i have changed the sub frame bolts fitted a link arm to the os and checked to see if all is tight an no play all ok
it is doing my head in  :mad:
next thing to check is the splines on the cv were it goes into the hub me thinks
Offline Mk5 GTian
  • -Receive: 37
« Reply #36 on: May 15, 2012, 10:50:17 pm »
Front ARB drop links? A few of us seem to be having this problem today!
Offline tomolambo
« Reply #37 on: May 16, 2012, 08:02:48 pm »
i have changed the os link arm already but ill grab another 1 tomorrow an give the ns ago
cheers
