Author Topic: Lost revo?  (Read 3735 times)
Offline Bazgti
Lost revo?
« on: March 17, 2012, 04:31:05 pm »
My revo stage 1 golf is awful at the mo. It feel very under powered to how it was. A mate of mine has jus said that if you get a flat battery the remap deletes. Is this correct?
Offline heavyd
  • -Receive: 29
Re: Lost revo?
« Reply #1 on: March 17, 2012, 04:43:36 pm »
you need someone with an sps device to reload your settings, or a revo dealer. the revo is still on the car, just the settings change
Offline nezquick
Re: Lost revo?
« Reply #2 on: March 17, 2012, 05:24:38 pm »
 Have you checked your diverter valve or pcv? if not id highly recommend doing so. my diverter valve was torn to shreds and fell apart when i took it out, felt soooo sluggish and snail paced and when i changed the vavle hey presto couldnt tell you how many times it was improved, car pulls like a train now!
Offline boxxer1973
Re: Lost revo?
« Reply #3 on: March 17, 2012, 05:29:06 pm »
If battery is disconnected revo goes into stock mode. Either get a sps unit or go back to any revo dealer they will be able to re aply the settings.
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
Offline AlanEdition30
Re: Lost revo?
« Reply #4 on: March 17, 2012, 05:32:47 pm »
Does it definitely go to stock mode when disconnecting the battery? As ive disconnected it when fitting a trickle charger and my revo still seems like the full fat mode?  :scared:
Offline boxxer1973
Re: Lost revo?
« Reply #5 on: March 17, 2012, 05:33:45 pm »
Yep spoke to revo and they said its a security thing
Re: Lost revo?
« Reply #6 on: March 17, 2012, 05:37:29 pm »
Thanks for the heads up i better make sure mine isnt on stock mode, though i doubt it, as it still feels quick  :driver:
Offline dan930
  • -Receive: 56
Re: Lost revo?
« Reply #7 on: March 17, 2012, 09:29:13 pm »
Is it only the revo map that does this??how about other maps?? Eg..r-tech
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Re: Lost revo?
« Reply #8 on: March 17, 2012, 09:37:44 pm »
Apr goes into lockout mode where you have to enter PIN to switch maps
Offline Janner_Sy
  • -Receive: 113
Re: Lost revo?
« Reply #9 on: March 17, 2012, 09:47:22 pm »
Mine doesnt :booty:
Re: Lost revo?
« Reply #10 on: March 17, 2012, 09:48:09 pm »
I'd rather it does. Security feature.
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
Re: Lost revo?
« Reply #11 on: March 18, 2012, 10:44:27 am »
Only Revo and APR map, I think  its due to the map switch options area in the code which is stored in the eeprom addaption memory which is non vilotile and can be reset by removing battery.
Your R-Tech engine & DSG maps will be fine if you lose battery power.
Nick
01455 617233
Offline R-tech-Nick
  • -Receive: 30
Re: Lost revo?
« Reply #12 on: March 18, 2012, 10:45:06 am »
If your local I can switch your Revo map setting back on £FOC if needed.
01455 617233
Offline Bazgti
Re: Lost revo?
« Reply #13 on: March 18, 2012, 03:45:22 pm »
Excellent! Thats very kind of you  :happy2: think im a fair bit away though mate. Im in oldham. Will av to nip up to awesome 2moro. Whats this SPS malarky n how much is it?
Re: Lost revo?
« Reply #14 on: March 18, 2012, 03:46:36 pm »
Best off looking in the classifieds for a used one.  £60 the going rate it seems
