Author Topic: Where to find OEM head unit security code  (Read 3058 times)
« on: March 19, 2012, 08:24:29 am »
Where would I find the head unit security code?  Would I have to plug it back into my car and vcds or can I ring the dealer and give them my vin number and they will supply it?
Thanks in advance
Re: Where to find OEM head unit security code
« Reply #1 on: March 19, 2012, 08:30:42 am »
Provided you only use that head unit with your car you shouldn't need it. Otherwise dealer should be able to get it with proof of ownership. Or someone on hear with the correct tool can reset it for you.
« Reply #2 on: March 19, 2012, 08:39:30 am »
A collegue want it for his Leon so dealer it is I think
Cheers Ian
« Reply #3 on: March 19, 2012, 09:03:14 am »
£35 if I refit stereo myself and book it into service where it's connected to a system at seat and a code is sent online
What equipment would be able to reset the code, do you know Ian?
 :drinking:
« Reply #4 on: March 19, 2012, 12:15:35 pm »
Sorry mate I'm thinking of the VIM cable that can also reset security codes on RNS510's.  :ashamed:
« Reply #5 on: March 19, 2012, 12:19:05 pm »
Hopefully a vcds wizard will be along to advise
Offline Image2000uk
« Reply #6 on: March 20, 2012, 07:21:32 am »
Mike
not sure if its the same but i know you normally just refit the stereo back into the car and it looks at the ecu code i believe and just works if they all match (i.e they came out of the same car) I know i did the wifes altea and my leon which was disconnected for several months and a aftermaket stereo fitted and they all worked when i put them back in. have even disconnected the battery with no problems.
Rgds
« Reply #7 on: March 20, 2012, 07:35:32 am »
Mike
Rgds
As mentioned above I'm wanting to put it in a friends Leon  :happy2:
« Reply #8 on: March 20, 2012, 08:25:36 am »
So Seat want to charge you £35 for the code to your original head unit that came with your car?   :fighting:
You would have thought that the dealer would be obliged to give you the info. It's your property and your info.
Surely it can be seen with VCDS like you say?
« Reply #9 on: March 20, 2012, 09:19:26 am »
Scandal  :fighting:
Hopefully a vcds wizard can advise me, I have access to genuine Ross tech
Offline james
« Reply #10 on: March 20, 2012, 09:35:37 am »
i am sure you cant see it in VCDS.   Dont you have the code in your hand manual?
Offline Image2000uk
« Reply #11 on: March 20, 2012, 11:04:31 am »
Mike
it should just work then if the stereo came out of the same car just plug it in and see you should not need vcds
Offline Image2000uk
« Reply #12 on: March 20, 2012, 11:10:04 am »
Mike
Just had another thought if its not in the handbook for the stereo it might be on the plastic tag which came with the car with the key numbers on it
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #13 on: March 20, 2012, 11:20:36 am »
You can't retrieve the Security code with VCDS.
When the unit is put in the car and the code first entered it is stored in the ECU. If for any reason you remove the stereo or battery for any great length of time (more than 2hrs iirc) when the battery etc is plugged back in the ECU sends the code to the unit to unlock it.
If you put it in another car it will not work and ask for the code.
You have 2 choices:
 - Take car to a dealer and retrieve the code with proof of ownership
 - As Ian says find someone with RNS Manager cable (Only 2 i know are VRStu and Eddie_NL) and they can reset the code for you.
HTH :happy2:
« Reply #14 on: March 20, 2012, 11:55:59 am »
Thanks Carl  :happy2:
Where are stu & eddie based?
