Author Topic: ATE power discs  (Read 2277 times)
Offline essoman
Re: ATE power discs
« Reply #15 on: March 28, 2012, 08:44:23 pm »
Anyone tried these on sale at Awesome-
Neuspeed Cross-Drilled Discs - Front (Pair) - Golf Mk5/Golf Mk6/TT2/A38P/Leo2/Oct2
Awesome Product Code: DEBR498
Every time you step on the brake pedal, your brake pads make contact with the brake rotor to slow your car down. The byproduct of that contact is heat, dust, and gas. NEUSPEED's cross-drilled rotors help dissipate this heat, dust and gas to reduce brake fade and cool down the rotor faster. NEUSPEED cross-drilled rotors are mill-balanced and each hole is ball chamfered to prevent cracking. All NEUSPEED rotors are cast to the original O.E. thickness for durability, and coated with a black-cadium finish to prevent internal corrosion.
Awesome recomend EBC red stuff pads.
£222 inc VAT and free delivery  seems a really good affordable upgrade for fast road use/occasional track work ?????
