Author Topic: Ideal Sub Set up for Summer 2012  (Read 2553 times)
Offline mvb12
  • -Receive: 64
« on: March 20, 2012, 01:20:58 pm »
Right - been thinking of getting the right set up for my baby for a wee while now and i think its time I look into this seriously.
Head unit - I'm keepng the RNS510 as it is (it really is a quality headunit) and will not be switching to an aftermarket, which I have done on all my previous rides.
Internal speakers/tweeters - I have always been a fan of directed type R because of the punch you get but wondering what else is a good look? have heard people talking about "Rockford Fosgate" being good, but has anyone used this brand before?
Amps - Directed Audio was my pride and joy rolling out with a 1200D, but as you amp heads know, Directed has been replaced by Orion which iirc is the same company so quality shouldn't be affected. HOWEVER, what other options do i have?
Capacitor - not necessary.
Oh and best wiring? i have no clue on this TBH!!!
so really after info on all except for the headunit.
Offline Tamiyoman
  • -Receive: 39
Re: Ideal Sub Set up for Summer 2012
« Reply #1 on: March 20, 2012, 02:16:46 pm »
I used to ignore Rockford Fosgate when I was younger as they were quite new to the "Scene" and all the american waffle put me off plus I did not like the chunky styling, preferred something more low key, used to swear by Pioneer speakers as personally preferred the sound although dynaudio do some good ones too.
Regards Amps I liked the (Back then) high end Amps made my Genesis (british made), gave amazing quality and sound and would recommend them back then.
Most Oxy free wiring sold by Retailers is likely made in the same 3 factories anyway  :wink: so that should not be an issue to find.
Offline mvb12
  • -Receive: 64
« Reply #2 on: March 20, 2012, 02:59:35 pm »
did you ever bother with sound proofing?
Offline Tamiyoman
  • -Receive: 39
« Reply #3 on: March 20, 2012, 05:09:43 pm »
Yes I did the front and rear doors and boot with Dynamat (I thinks thats what it was called, it was nigh on 17 yewars back now lol), never bothered with the floorpan  :happy2:
Offline mvb12
  • -Receive: 64
« Reply #4 on: March 20, 2012, 07:51:11 pm »
oxy free wiring - what sort of price should i be looking at.
Offline GINGER224
« Reply #5 on: March 21, 2012, 08:01:39 am »
Pop to halfords as they have various gauges of all wires to suit your budget on the Walls in reels.
Offline MrP
« Reply #6 on: March 21, 2012, 09:10:17 am »
Make sure you get copper cable.
as coppers gone so expensive i hear that alot of cable is now aluminium with a copper coating, but its no where near as good.
Offline Tamiyoman
  • -Receive: 39
« Reply #7 on: March 21, 2012, 09:46:06 am »
Wouldn ignore halfrauds you can get it much cheaper looking on either ebay (UK, ignore the crap from china) or amazon, make sure its 100% copper Oxy free and you should be ok.
Offline mvb12
  • -Receive: 64
« Reply #8 on: March 21, 2012, 12:52:38 pm »
so there is not actual brand to look for in terms of wiring?
Offline MrP
« Reply #9 on: March 22, 2012, 11:07:54 am »
some are better than others, but i havent seen any reviews comparing them recently. however, i'd keep half an eye on the tickness of the plastic coating, it may say 4 guage, but if the coating looks a bit thick, compare it to another 4 guage cable
proper car audio stuff is nice and flexible, if you wanna save money, buy some welding cable, still copper, does the same job but not as fancy/flexible/whatever
« Last Edit: March 22, 2012, 11:09:56 am by MrP »
Offline mvb12
  • -Receive: 64
« Reply #10 on: March 22, 2012, 12:09:03 pm »
what about door speakers? would you say stick with alpine and pioneer?
Offline MrP
« Reply #11 on: March 22, 2012, 01:13:41 pm »
no idea to be honest, depends on what you wanna spend, what you listen to, how your using them (powered of head unit or amp) all sorts.
the top line pioneer stuff (ODR costing thousands) is amazing, the cheaper stuff, i dunno.
Offline Snoopy
  • -Given: 31
« Reply #12 on: April 01, 2012, 04:44:31 pm »
As Mr P said keep an eye out for wire with the letters cca on it as that's copper clad aluminum and more resistive than copper. Had this come into work before. Also as he said keep an eye on cross sectional area v wire coating. Rebranded China makes often have little copper cross sectional area.
Offline jameelno1
  • TDI Power
« Reply #13 on: April 01, 2012, 11:57:15 pm »
as the golf has 3 way component speakers you have a choice from focal, then hertz, jl, rainbow, a/d/s, morel
subwoofers u have a good range from alpine, jl, orion, fi btl, pioneer, etc. ive got 2 alpine type r's
amps good ones genesis, jl, orion, zapco, etc.
any 4 guage wiring will do copper one are best
a good agu fuse 90amp or above
power caps are not needed thou they help even the voltage out from spikes. i have one in mine a vibe 1.5 farad as my lights dimm when thelow bass drops still didnt help  :signLOL: even with as bigger battery looks like i need the big 3.
anymore info u need just ask ill try and help  :happy2:
golf mk5 1.9 tdi
« Reply #14 on: April 02, 2012, 12:45:12 am »
I might ask for some help wiring an amp and sub to the RNS510....a bit later in the year.  :ashamed:
