Author Topic: Vagcom - clearing air bag warning light for mvb12  (Read 968 times)
Offline nezquick
« on: March 23, 2012, 08:39:29 am »
Hi just a quick question if anyone could point in the right direction.
Scanned mvb12's car for him yesterday to clear the air bag light he induced by taking the cable out when changing to a new radio/nav. I scanned the car and found a few small code errors such as the gps not being 'coded' etc etc and saved a log and then cleared all code errors. waited to finished, took vagcom out and started the car which it did (phew - always a nervous moment) but the air bag light is still on. I advised double checking everything was plugged back properly because I know the clips can be quite stiff. The other thing that makes me think it hasn't been put back properly is I went to turn the air bag off in the glovebox and the "Airbag off" sign under the hazard light button didn't illuminate.
Any ideas?
 :happy2: :popcornsoda:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Vagcom - clearing air bag warning light for mvb12
« Reply #1 on: March 23, 2012, 10:00:06 am »
First port of call would be to check it was all put back together properly and the connections are together properly.
Offline mvb12
  • -Receive: 64
« Reply #2 on: March 23, 2012, 10:52:41 am »
i shall check this today and revert.
Offline apples12
« Reply #3 on: March 23, 2012, 11:46:11 am »
also in order for the gps/rns 510 to be 'coded' you must set a workshop code/id in your vagcom tool  :happy2:
MK6 GT TDI  - CW - LUX pack
GONE
Offline mvb12
  • -Receive: 64
« Reply #4 on: March 23, 2012, 08:19:59 pm »
so after work i got stragith to work on the bugger, pushes the plug right up itself anf the light on the centre console is now on. so i just the connection was missing last time round?
Offline nezquick
« Reply #5 on: March 23, 2012, 08:47:33 pm »
 :wink: that would be it! ill clear it on sunday for you!
Offline mvb12
  • -Receive: 64
« Reply #6 on: March 23, 2012, 09:20:28 pm »
cheers much appreciated.  :happy2:
