Author Topic: ET advice  (Read 4558 times)
Offline evvo
    • Moshi Monsters Cheat Codes
ET advice
« on: May 08, 2009, 01:04:56 pm »
Ok looking at some new rims and just need to know how low an ET i can go the wheels im looking at are ET 20 so i think there a no no but just wanted to check whats the lowest anyones gone?
Completly standard 1977 Miami Blue MK1 Polo N 27500 miles one owner from new!
Offline iainalpine
Re: ET advice
« Reply #1 on: May 08, 2009, 01:44:39 pm »
EVVO, I am fitting et35 19" 8.5 and its gonna be tighter than a ........... so so et22 in my book would be a nightmare.
You would need arches like "X5PEA" has got on his mk5
Iain
2006 MKV GTI, DSG, Stg2 Revo map, VWR front splitter, KWv3's, Eibach rollbars, Walk kit, Carbonio induction kit, Full Milltek exhaust system, Forge FMIC
Offline joesgti
  • Eat my sick, Eat my sick.
Re: ET advice
« Reply #2 on: May 08, 2009, 01:45:53 pm »
no way mate, youd need arch work!  :smiley:
Offline evvo
Re: ET advice
« Reply #3 on: May 08, 2009, 02:07:52 pm »
yeah thought that would be the case. Cheers so no lower than ET35 for standard arches
Re: ET advice
« Reply #4 on: May 08, 2009, 02:12:50 pm »
I would say no lower than 42  :smiley:
Offline Norbreck21a
Re: ET advice
« Reply #5 on: May 08, 2009, 02:14:02 pm »
Also depends on the rim width (7½", 8", 8½" etc.)
I have 18" x 8" Rims on mine with an ET of 42, and they are pretty much flush with the inside edges of the wheelarch.
Offline BeezerDiesel
  • -Given: 33
Re: ET advice
« Reply #6 on: May 08, 2009, 03:28:20 pm »
I've got 8x18 ET44 and it catches on the front occasionally on speed humps, sits very flush to the arches.
Andy
7R
Offline tony_danza
  • -Receive: 112
Re: ET advice
« Reply #7 on: May 08, 2009, 04:00:53 pm »
^ Ditto, mine are the same size and I wouldn't want them any further out.
Sideways yo!
Offline scarpicus
Re: ET advice
« Reply #8 on: May 08, 2009, 05:27:35 pm »
my wheels are 18x8 ET40 and im sitting flush as well.
if you plan to go a lot lower than the lowest offset i would get would be about 45
i regret in someways getting wheels with such a low offset as i want to go lower but i may have problems as i have posted about today. :happy2:
Offline The wheel man
Re: ET advice
« Reply #9 on: May 08, 2009, 06:15:33 pm »
Remember that the lower the offset, the lower the number, the further the wheels will sit out. So if you wanted the offset lower than 40 you will be looking at 35.  Ive got 18x8 ET45 on the front and i woulddnt go much further than that, as TC says ET42 on an 8" is plenty for the front.  probably be OK with 35 on the rear though......j-u-s-t  :happy2:
APR cat back, ECS Insert
Offline scarpicus
Re: ET advice
« Reply #10 on: May 08, 2009, 06:34:09 pm »
x2
Offline TurboTrev
Re: ET advice
« Reply #11 on: May 08, 2009, 09:32:31 pm »
From my experience with 19" MK5 alloys, if you don't want to push the limits of fit, I would say ET45 to ET 50 on the front and ET40 to ET50 on the back.
Offline evvo
Re: ET advice
« Reply #12 on: May 13, 2009, 08:10:04 am »
So do you recon I'd get away with ET35 on a set of 19"x9"? or would that be to much poke bearing in mind i could go treched tyres to pull the tread back under?
Re: ET advice
« Reply #13 on: May 13, 2009, 09:26:34 am »
Still no  :grin:  That is a couple of mil short of 2 inches further out than a Monza II.
You could weld a little bar to the wing and have it as a hamster treadmill.  :laugh:
Re: ET advice
« Reply #14 on: May 13, 2009, 10:17:57 am »
:grin: :grin: :grin:
