Hello guys,
I'm currently on Revo stage 3 (AXX engine code with 10.5:1 compression ratio). For the past 3 years I've been using B9-T7-F9 with 99-100 octane gasoline and the logs looked great (very good performance either). However, on the track, I've had some engine overheating problems and on the last track day, a water plastic pipe broke and lead to the water pump and head gasket failure. Knowing this, I would like to ask all of you what safer settings do you recommend for track use ? (with 9-7-9 the car makes approx. 370HP/460NM but I can happily accept 330-340HP for more reliability/lower oil&water temps) !
