Author Topic: Edition 30 - footwell/ wishbone clunk????  (Read 1669 times)
Offline Lex
« on: March 28, 2012, 11:07:45 pm »
Has anyone had or heard any clunks from the footwell area when going from reverse to forward??
I reverse off my drive and it makes the clunk/ click noise??
It happens when I am turning usually on full lock at slow manuveres....
I am thinking a WALK kit will fix it??
Any similar probs??
Any cures?
Apart from that little annoyance  it's a great motor??
All help and advice appreciated......
Oh it's in for minor service at the stealers next week, I did mention it last time but they did their visual check and found nothing wrong  :confused: !?!?!?!?
Offline Beddie
  • -Receive: 76
Re: Edition 30 - footwell/ wishbone clunk????
« Reply #1 on: March 29, 2012, 06:35:45 am »
Could be the 'subframe clunk', getting to become quite a common fault lately it seems, maybe give the ECS tuning subframe bolt and spacer kit a try? Only £15 from most uk retailers or around £9 if you buy the parts from the dealer   :happy2:
Basically what happens is that the subframe bolts become loose over time allowing the frame to move slightly causing a knock / noise, the kit usually sorts it if this is your problem but I'd also recommend going over all the other frame bolts whilst it's up on the ramps
Carbon Grey Edition 35 - Here
Offline alackofspeed
  • -Receive: 24
« Reply #2 on: March 29, 2012, 05:58:28 pm »
Offline neil86
« Reply #3 on: March 29, 2012, 06:27:14 pm »
I am getting this a long with many other noises. I thought it was my coilovers spring moving in the seat.
I have bought the kit not had chance to fit yet but had a look at my bolts there not loose and no marks from movement so unsure whether to bother fitting.
Offline dmac1969
  • -Receive: 21
« Reply #4 on: March 29, 2012, 09:09:58 pm »
Mine does it too!
Offline Lex
« Reply #5 on: April 19, 2012, 10:44:09 am »
hey guys thanks for your input
as ever the stealers say they checked everything and could not find the fault and gave it a clean bill of health and took my money!?
anyway next day coming off the drive.......clunk.
hmmm
ok maybe Awesome will be better.
i will try the kits mentioned.
at least i am not the only one its happening to!
mines a 56 plate 07 car?
Offline Beddie
  • -Receive: 76
« Reply #6 on: April 19, 2012, 10:49:11 am »
I had the bolt and spacer kit fitted last week and it's stopped my 'knock', for now... :happy2:
£6.87 from the dealer with a little discount and 10 mins to fit whilst it was on the ramps having some work on the brakes done, popped a new power flex lower mount in whilst we were at it too  :smiley:
Offline Lex
« Reply #7 on: April 19, 2012, 11:11:06 am »
hi there
do you have part number for this bolt and spacer..?
cheers?
Offline Beddie
  • -Receive: 76
« Reply #8 on: April 19, 2012, 12:07:05 pm »
7M3499349A  - Plate x 2 @ £1.72 each
N90823501 - Bolt x 2 @ £2.24 each
I got 10% off the spacers and 19% off the bolts so a total of £8.08 with the vat for the full kit
Offline AndyED30
  • ED30
« Reply #9 on: April 19, 2012, 12:09:58 pm »
Just worth mentioning....................
I recently had my springs removed and replaced with some H&R ones.
The old (standard) ones were on upside down and were causing a clunk ONLY when going very slowly coming off from my driveway or going back onto it. The guys who fitted my new ones let me know and this explained it.
Maybe worth a check?
Andy.
Offline dmac1969
  • -Receive: 21
« Reply #10 on: April 19, 2012, 09:31:53 pm »
Andy.
Does that mean the factory put them on the wrong way round?
Offline AndyED30
  • ED30
« Reply #11 on: April 20, 2012, 12:35:17 am »
[/quote]
Doubt it but mine have been changed previously which is when it happened. If yours have, then worth checking I guess.
