Author Topic: Help from someone with ETKA (Audi)  (Read 7263 times)
Offline sub39h
  • -Given: 189
  • -Receive: 84
« on: March 30, 2012, 09:03:59 am »
Hi guys,
I'm looking for all the part numbers to the bits for the rear parking sensor system from the MY09+ A3s. Everything from the CECM backwards. Can anyone help?
Thanks,
S.
« Last Edit: March 30, 2012, 09:10:04 am by sub39h »
PLANS: Stage 2+
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Help from someone with ETKA (Audi)
« Reply #1 on: March 30, 2012, 10:46:14 am »
I had a 60 plate S3 -
Quote
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 G    HW: 8P0 907 063 G
   Component: BCM PQ35  M   107 0615
   Revision: 00107 AF
   Coding: 4E000A2FA005F0C0207241E02100095C427E2BAA316DD928E40008840040
   Shop #: WSC 06314 000 00000
   VCID: 3874A25D3238
Quote
Address 10: Park/Steer Assist (J446)       Labels: 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93641014901320
   Coding: 000103
   VCID: 4280C0B564E4
Quote
Address 19: CAN Gateway        Labels: None
   Part No SW: 8P0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H32 0302
   Revision:   H32       Serial number: 030510F1019629
   Coding: EDA37F0640061200002103
   VCID: F0E4DA7D9AC8
Stu...
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: March 30, 2012, 10:53:25 am »
thanks! so the one in the middle is the module, one at the top is the CECM, what's the bottom one for?
also i need the p/ns for the wiring looms between them and the speaker too
(i've got a 2006 A3 with an aftermarket parking sensor system - i'm having the 09+ S-Line rear bumper installed and it happened to have factory sensors with it. i just need the wiring and the module so i can plug it all in so it works!)
PLANS: Stage 2+
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: March 30, 2012, 11:04:17 am »
The interface varies depending on 4 or 8 sensors and if is includes park assist (side sensors).
PARKHILFE 4K means it's a 4 sensor interface.  The interface sits in the boot area.
You will need to pick up CAN Hi & Lo as well as power and ground.  You won't get ready made looms from Audi.  Kufatec would be the best option for that.  You won't beat the prices or ease of using one of their looms -
http://www.kufatec.de/shop/product_info.php/info/p570_c48_PDC-Park-Distance-Control-Rear-Sensor-Harness-Audi-A3-8Pand-8P.html
http://www.kufatec.de/shop/product_info.php/info/p571_c48_PDC-Park-Distance-Control--Central-Electric-Harness-Audi-A3-8P-and.html
I have given you the number of a suitable controller so all you need is the buzzer which normally sits in the door pillar.
Stu...
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #4 on: March 30, 2012, 11:07:58 am »
where can i get the stuff in bold from? sorry i've tried searching for info for this for weeks but have found very little - which is perhaps understandable because of the expense
« Last Edit: March 30, 2012, 11:09:38 am by sub39h »
PLANS: Stage 2+
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: March 30, 2012, 11:16:33 am »
CAN Hi & Lo you don't 'Get', it's the Controller Area Network in your car used to communicate between all controllers and the CAN Gateway.
If I were you I'd buy the Kufatec looms mate.
Stu...
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #6 on: March 30, 2012, 11:20:24 am »
oh assumed they were something you needed to buy/install  :signLOL:
so with the 2 kufatec looms it's plug and play, provided i get a speaker?
PLANS: Stage 2+
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: March 30, 2012, 11:20:36 am »
I also don't think you can just change the CECM as the later ones changed to BCM (Body Control Module) and included the CECM and Comfort System in one unit.
You might not need the CECM.
Stu...
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #8 on: March 30, 2012, 11:22:37 am »
do you know what byte CECM i'd need?
PLANS: Stage 2+
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: March 30, 2012, 11:24:27 am »
Yes the speaker is a very simply two pin unit almost identical to this -
http://www.ebay.co.uk/itm/ASTON-MARTIN-DB9-PARKING-AID-SPEAKER-/170773916242?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27c2eb2a52#ht_500wt_983
You can see the plug for the speaker on the wiring loom picture at Kufatec, it's labeled warnsummer
Stu...
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #10 on: March 30, 2012, 11:26:24 am »
i've already got a speaker from a 2004 car. i've also got it's module, which i understand might work with my new sensors, but the rear sensors were the wrong type as was the wiring, and the bits from the CECM to the module weren't included so i've got a bit of a mish-mash of parts and no real clue how to get it all working  :laugh:
PLANS: Stage 2+
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: March 30, 2012, 11:28:03 am »
My 57 S3 had rear parking -
Quote
Address 09: Cent. Elect.        Labels: 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
   Component: Bordnetz-SG     H54 2501
   Revision: 00H54000    Serial number: 00000007472475
   Coding: ED8E1F07A0141000470000000000000000084E175A050002000000000000
   Shop #: WSC 06314 923 00000
Quote
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K077190251
   Coding: E9831F0E4006020101
Quote
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283 D    HW: 8P0 919 283 D
   Component: Parkhilfe 4-Kan H09 0070
   Revision: 00H09000    Serial number: 00067824820721
   Coding: 0000113
   Shop #: WSC 131071 1023 2097151
Notice on the newer cars the controller has a different assignment. (76 older, 10 newer)  This relates to the controller and it having OPS or not.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #12 on: March 30, 2012, 11:28:35 am »
The speakers will be the same, old or new.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #13 on: March 30, 2012, 11:30:05 am »
The wiring will differ if the Parking unit is newer or older - 10 is connected differently to 76.
If I were you I'd go with 76 and older stuff unless you want to try and get OPS but you need to add front sensors and have a late RNS-E for that.
Stu...
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #14 on: March 30, 2012, 11:42:03 am »
the only reason i've done it this way is because a member on Audi Sport back when i was a member had newer sensors plugged into his old module from his factory sensors and it all worked fine. around the same time the 2004 sensor kit came up for sale for a reasonable price so i went for it.
the difference with me, ofc, is that i don't have factory sensors so the plan was to use the older wiring from my CECM to the module, and then the newer wiring from my module to the speakers. it can't harm to try, and if it doesn't work i'll sell the sensors with the kufatec loom to get some of my money back. i'm just worried my CECM won't support sensors at all, tho i'd be surprised because i've got auto lights/wipers on my car and a couple of other high spec bits.
not all MY09+ 8Ps have front sensors, so i'd be surprised if that was an absolute requirement to getting it all working. in fact i know of more than one person who've just fitted the rears so fingers crossed it should be fine. if not, well i've already got the late model RNS-E so maybe i'll just fit front sensors as well lol. i've actually got 4 spare after all!
thanks very much for your help mate - i owe you a pint or something definitely. i've asked these questions before on other forums and nobody has been anywhere near as helpful as you, even people who i know know the answers!
PLANS: Stage 2+
