Author Topic: CANBUS  (Read 2324 times)
Offline Gazza747
CANBUS
« on: March 30, 2012, 10:47:07 am »
Hi all,
I need to change the RCD300 in my 07 plate golf gti. I'm looking at preferably the RCD510 or an aftermarket head unit. Will I need to do something with the CAN BUS with either replacement replacements and if so what is the cheapest solution i.e. modify wiring, get adaptor etc.
« Last Edit: March 30, 2012, 02:13:08 pm by GAZZA747 »
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline vRS_Pagey
  • -Receive: 59
Re: CANBUS
« Reply #1 on: March 30, 2012, 01:58:57 pm »
Depending on the version of gateway you have it may need changing to avoid battery drain, iirc you need a rev' k or newer.
Offline Gazza747
Re: CANBUS
« Reply #2 on: March 30, 2012, 03:10:37 pm »
After a phone call it appears that the only issue is with installing a mk6 radio into a mk5 car. Could somebody tell me what I need for my 2007 golf gti (i.e. adaptor/new unit) and where it is on the car!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Cluster and Key coding
Location Great Yarmouth
RichardSEL
Re: CANBUS Passat
« Reply #4 on: April 03, 2012, 01:18:16 pm »
Hi...
Any Passat refugees in here?
Need Gateway as mine's the olde C revision
Part# is 3c0 907 530 anything M or later?
Eddie?
RichardSEL
... I think I'll go back to my Rover P5 if you don't mind :driver:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
