Author Topic: RNS 510 question. Updated Question!!!!  (Read 11027 times)
Phil Mcavity
« on: May 09, 2009, 10:00:30 am »
Im guessing i know the Answer to this one..
Ive just bought and fitted one this sat Nav to the car. My multi funtion steering wheel controls are not working in conjuntion with the Nav. Is it a setting in the RNS510 , or find someone with Vag com to re-instate Nav with wheel.Its just the voloume control and track up/down. the rest of the wheel controls all operate.#
VRStu is normally the person who is closest but hes away, anyone else near southampton with VCDS (Hedge) Ian if you read this, can i contact you?
Cheers guys
« Last Edit: May 11, 2009, 01:58:45 pm by Phil Mcavity »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: RNS 510 question.
« Reply #1 on: May 09, 2009, 10:04:30 am »
VCDS will be need for this one Steve  :happy2:
Offline clive_gti
« Reply #2 on: May 09, 2009, 10:15:34 am »
My MFSW buttons all worked after installing the RND-510 (without intervention from VCDS)
Offline CocoPops
    • Kennet Heath
« Reply #3 on: May 09, 2009, 10:16:11 am »
I have VagCom Steve but would need to know the settings.
Used to Own: 2008 GTI Ed30 | ITG Intake | Miltek TBE System | Bluefin Stage 2 | 327bhp
On Order: 2017 Golf GTI Performance Pack 5dr DSG
Also own: 2016 Lotus Evora 400
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #4 on: May 09, 2009, 10:16:57 am »
What did you have before Clive??
Offline cmdrfire
    • Commander Fire - my blog
« Reply #5 on: May 09, 2009, 06:46:44 pm »
Same thing has happened to me!
I have the old MFSW without the star button. The newer MFSW with the star button works straight away, but on the older MFSW the track+/track-/source buttons don't work on the wheel. Instead the track+/track- functionality is on the MFD (highline computer) control stalk buttons. A bit annoying but I've not had time to sit down and look at it.
Offline 182_blue
  • -Receive: 54
« Reply #6 on: May 09, 2009, 11:44:05 pm »
it all depends how it was set up previously
Phil Mcavity
« Reply #7 on: May 11, 2009, 01:58:13 pm »
just an update, ran my car down to the dealers for them to "quickly" plug Vag com in to see whats wrong.
They have drawn a blank so far as to why its not working. Theyve changed the settings so that the car thinks its an 08 model,as when they then fitted the RNS510 as an option, but for some reason it wont find the mfsw as being connected to it, although everything else works ie bluetooth kit, but volume/track up/down, Telephone/star buttons again no longer work.
They said it could be a loose cable at the back of the sat nav???, but its the huge loom which cant be loose as its a click in type?? and as ive said everything else works??.
Have a missed a wire off the back of the unit?
Is there such thing as an update of drivers for the RNS510?.
ive drawn abit of a blank on this. Anyone any ideas?.
Dealership want to pull the sat nav back out and check behind it?? not sure this will resolve anything.
My MFD2 worked perfectly with these buttons so surely cant be wiring fault imo??
cheers guys
Oh, and when i was there the new Mark 6 GTi was being put in the showroom. Candy white, 5 door manual, and my opinion was of more disapointment . Not as good as i thought tbh, but thats another story.Liked the new rear diffuser and pipes. Test drive on the 19th already arranged  :smiley:
Cant drive it any earlier as VW UK have said no test drives till official uk launch on the 19th.
« Last Edit: May 11, 2009, 10:24:46 pm by Phil Mcavity »
Offline 182_blue
  • -Receive: 54
Re: RNS 510 question. Updated Question!!!!
« Reply #8 on: May 11, 2009, 07:01:55 pm »
^ you can update the firmware on the unit, do you know what version its running ?, not that i think this is the issue, do you think the dealers knew what they were doing ?
Offline uz
« Reply #9 on: May 11, 2009, 08:23:45 pm »
I had the same problem on my unit which replaced the bog-standard RCD300. I took it back to the guys that supplied it straight away and with a bit of tweaking on Vag-Com they managed to sort it.
They're based up in Leicester so not local to you, but I can PM their details as they may be able to give you some info over the phone??
Steel Grey GTI Ed.30 - 18" Team Dynamics Pro Race 1.2 - Eibach SportLine Springs - RNS510 - Bluetooth Adapter Package - Winter Pack - Open Grilles
SOLD: Candy White GTI - 18" Monza 2's - RNS510 - Premium Bluetooth - Winter Pack - Xenons
Phil Mcavity
« Reply #10 on: May 11, 2009, 09:03:52 pm »
update, Hedge (Ian)  :drinking: has been here for best part of a couple of hours here trying to solve this.
He seems to think that the steering wheel controllers were superseded on the later 08 model cars and that mine being a early ed30 is different (56) , Although mine has MFD2  as the RNS510 wasnt out and the wheel has been updated since to suit. ( part numbers are different from his car to mine.)
Cars is still in to VW dealers tommorow whilst they give me a Golf + to try out :sick:, to try and solve this problem. Tis abit of a head scrather.
« Last Edit: May 11, 2009, 10:25:48 pm by Phil Mcavity »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #11 on: May 11, 2009, 09:07:15 pm »
Do you have an VCDS autoscan report from Ian to compare the CAN gateway and steering controller versions?
« Reply #12 on: May 11, 2009, 09:54:31 pm »
Yes we do.
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0013122
   Shop #: WSC 01279 785 00200
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
No fault code found.
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 28100602000837
   Coding: 3F3F03C807000003
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 215
                    Mileage: 49973 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:07:46
01303 - Telephone Transceiver (R36)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 215
                    Mileage: 49959 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:14:12
« Reply #13 on: May 11, 2009, 09:57:57 pm »
My CAN Gateway
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 160408F1003273
   Coding: ED807F0E4006020003
   Shop #: WSC 06314 923 00000
and wheel
Address 16: Steering wheel        Labels: 1K0-953-549.lbl
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0101
   Coding: 0013122
Phil Mcavity
« Reply #14 on: May 11, 2009, 10:14:11 pm »
anyone have any thoughts???
cheers again Ian :drinking:
