Author Topic: RNS 510 question. Updated Question!!!!  (Read 11016 times)
Offline pazz
Re: RNS 510 question. Updated Question!!!!
« Reply #45 on: May 13, 2009, 01:16:13 pm »
and the later as well!!, mines the later and have the RNS fitted!.If you have from 56 to 57 reg's and have MFSW, you'll need the steering control module changing.
Hmm, when you bought your new buttons did the steering wheel controller get changed at the same time?
Phil Mcavity
« Reply #46 on: May 13, 2009, 05:15:15 pm »
I have the AL steering control module with the newer type buttons. I had to take my mfd2 out the other day for repair so turned all the coding off for nav and radio on vcds,
One of my mates is a VW/Audi technician and has a few of these rns-510's laying about so we tried one which was a 2008 build and with out any coding or any thing the rns-510 worked with my steering buttons.  I will be purchasing one of these once I've got the money together.
Phil if you need my mates number to have a word with just send me a pm and ill pass it on,  He actually does all the auto electrical stuff for audi in leeds,  so he knows his stuff if he doesn't know then maybe Ray user name (aRd) over on www.uk-mkiv.net
Darren
morty, mine is a 56 plate 07 build hense the issue with module and buttons. Works on 08 builds hense why yours works fine :happy2:.
Waiting for part to arrive so to sort it out. :happy2:
Phil Mcavity
« Reply #47 on: May 21, 2009, 06:48:36 pm »
steering controller tried and tested, didnt work!! so Pazz, what do i need to do to change can bus from K to L to resolve??.
i have no idea what a Canbus is!!
Offline pazz
« Reply #48 on: May 21, 2009, 07:12:30 pm »
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 28100602000837
   Coding: 3F3F03C807000003
   Shop #: WSC 01279 785 00200
Phil's CAN Gateway: 1K0 907 530 K
My CAN Gateway
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 160408F1003273
   Coding: ED807F0E4006020003
   Shop #: WSC 06314 923 00000
Hedge's CAN Gateway: 1K0 907 530 L
Offline JonnyG
  • Golf R
« Reply #49 on: May 22, 2009, 07:23:09 pm »
Darren
Ooh, I live in Leeds  :laugh:   If your mate wants to put an RNS 510 in my R32 just PM me a quote and contact no.   :wink:
I also want Cruise retrofitting, so would like the lot done together  :party:
Golf R, 5dr, DSG, March 2010, Rising Blue, 19" Talladegas, Cruise
Offline TagnuT
« Reply #50 on: February 18, 2010, 07:59:04 am »
My CAN Gateway
Did you get your MFSW buttons to work ok in the end? Was it the CANBUS?
My MFSW buttons worked with my RCD300 to change track but when I fitted a RCD510 that stopped working. Volume/mute/menu buttons are ok. Just track selection from the RH buttons... :sick:
Bye Bye Edition 30.
