Author Topic: RCD510 in 05 GTI  (Read 1396 times)
Offline craig_t
  • Craig
RCD510 in 05 GTI
« on: March 31, 2012, 02:51:31 pm »
Just fitted a RCD510 into my 05 gti. Now I know that this unit can give battery drain issues if the CAN isn't the right one. Does anyone know how long it will take to drain the battery as I'm doing this as a test to see if it drains or not.
Are we talking a few hours? Overnight? Days?
Admin notice, sig pic removed for being to big.
Offline boulevard
Re: RCD510 in 05 GTI
« Reply #1 on: April 01, 2012, 01:58:33 pm »
I recently had an RNS510 fitted into my 06 GTI and had the CAN changed over. I was told when I enquired bout the drain its likely to be overnight so you should know tomorrow... I kept pulling the fuse out till I got my CAN done to save the battery, just meant it took afew mins for the GPS to locate but otherwise was a good temp measure.
Black GTI Mk5 - got cruise, RNS510 & Carbonio intake to be fitted next..
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: April 01, 2012, 02:50:56 pm »
if you use the car a lot, could take a few days
Cluster and Key coding
Location Great Yarmouth
Offline craig_t
  • Craig
« Reply #3 on: April 02, 2012, 06:21:59 pm »
Left the unit in over night and the car started ok just now do I guess I'm one of the lucky ones!!!!!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: April 02, 2012, 06:37:55 pm »
give it few days before you break out the champagne
Offline craig_t
  • Craig
« Reply #5 on: April 02, 2012, 06:51:29 pm »
How many days do you think will defo let me know?
Offline craig_t
  • Craig
« Reply #6 on: April 02, 2012, 10:49:11 pm »
Ah well my battery did go flat :(
Looks like I'm going to have to get a new CAN. Will it be ok to put my old rcd300 back in and still replace my CAN. Will this affect my old unit?
Also is there anyone in the Bedfordshire area that could help me fit and programe the new CAN.
Craig
Offline craig_t
  • Craig
« Reply #7 on: April 03, 2012, 08:15:20 pm »
Because of the battery drain I have removed the rcd510 and put in the old rcd300. But when I started the car up again I now have the light on the dash below and can't turn the traction control off.
Does anyone now what iv done and how I can sort this?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: April 03, 2012, 08:16:12 pm »
take it for a short drive
Offline Kevga
« Reply #9 on: April 08, 2012, 04:18:05 pm »
Its approx 12 hrs for it too drain your your battery and as previously said take it for a drive or charge the battery and once you start it up again these warning lights should go out  :happy2:
My pic was to big.
Work In Progress
