Author Topic: APR TFSI intake  (Read 17155 times)
Offline donnyboy
Re: APR TFSI intake
« Reply #15 on: December 11, 2012, 09:41:21 pm »
Thats interesting you went back to standard. I do also like my car quite, and low down torque is where i do most of my driving. Don't do many long, high speed runs.
Offline Marshall
Re: APR TFSI intake
« Reply #16 on: December 11, 2012, 09:44:49 pm »
You sound like me then, this is probably the only one to go for if you want one that is.
I've wasted a fortune on intakes forgot to mention the itg maxogen (noisiest of all the ones I've tried)
MISANO RED RS3
Re: APR TFSI intake
« Reply #17 on: December 11, 2012, 09:47:30 pm »
I would think it compares very well to the ITG as afterall that is what it is.  :confused:
  • -Receive: 427
Re: APR TFSI intake
« Reply #18 on: December 11, 2012, 09:51:00 pm »
^^^^  does look like the newer ITG with its canister.
@KEVS FR
Found my last ITG (a Maxogen)  a bit much re the sound on my Eddy and yes your right about the loss of low down go. I'm currently between CAI's (next ones a Twintake) and running an aftermarket panel filter with OEM engine cover without any noticeable loss of grunt. The APR/VWR system does look good though (with a lot less connections than the ITG) and should be quieter with its canister.
« Last Edit: December 11, 2012, 09:53:25 pm by MC71 »
Offline Marshall
Re: APR TFSI intake
« Reply #19 on: December 11, 2012, 09:56:24 pm »
The loss of low down grunt from the twintake is the same as the itg maxogen.
I used to love the twintake on my previous k03 car but not on k04 lost a small fortune in 2 weeks use.
As I say I think my car is more powerful on panel filter than any intake I've tried.
MISANO RED RS3
Offline donnyboy
Re: APR TFSI intake
« Reply #20 on: December 11, 2012, 09:58:55 pm »
Be interesting to hear from anyone that has one. Maybe APR have more info.
  • -Receive: 427
Re: APR TFSI intake
« Reply #21 on: December 11, 2012, 10:13:19 pm »
I'm sure all the previously mentioned CAI systems will suffer the same lag low down. I will stick it on and see.  :happy2:
Offline 56OctyVRS
  • -Receive: 72
Re: APR TFSI intake
« Reply #22 on: December 12, 2012, 12:26:03 am »
@KEVS FR
Ive switched back to the engine cover and going from having a performance panel filter installed to a standard paper filter. There has been no difference in performance. I am just sticking to changing the filter every service rather than a performance filter.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: APR TFSI intake
« Reply #23 on: December 12, 2012, 11:49:26 am »
Funny APR hasn't responded to this tread yet??  :confused:  :signLOL:
Over the top mod list ;o)
Offline Keith@APR
  • -Receive: 36
    • Go APR
Re: APR TFSI intake
« Reply #24 on: December 12, 2012, 12:45:37 pm »
Here is the deal with intakes for the 2.0T FSI.....
The 2.0T FSI has a very uniquely shaped maf housing.  The shape and diameter of the housing as well as the flow straightener integrated into the housing has a very direct and precise influence on the calibration of the maf sensor and how accurately the maf sensor reads.
In the past and on other VAG engines, the maf housings are not that unique and and the maf sensors themselves are not as affected by small differences in the housing.
All intake manufacturers followed their normal design and manufacturing procedures of recreating a similarly sized maf housing for their product which to insert the maf sensor.  During initial prototyping, most intake manufacturers use a more precisely manufactured housing than when they go into production.
Almost all intakes currently available to this day that include a new mounting point for the maf sensor are manufactured with methods that do not allow for precise enough tolerances regarding the diameter of housing around the sensor and can be too large and too small to a point that creates improper maf readings.  They can also be spot on.
Some intakes currently available to this day also include mistakes in the design regarding the specificity of the shape, flow straightener and placement of the maf sensor, which was not as important on previous VAG engines.
APR and Carbonio have tried nearly every method of cost effective manufacturing to repeat the tolerances required to ensure that every intake we would sell would be sized properly for the maf sensor's calibration.  APR and Carbonio have tested batches, usually 3-5, of nearly every available intake for the 2.0T FSI.
We have found that sometimes you can get a perfect maf sensor reading and sometimes you can't.  The manufacturing processes used simply don't allow for precise enough results.  We have tested intakes made from bent tubing of various metals, plastic injection molding, rotoformed tubing, plastic cast tubing and carbon tubing.
The most cost effective method available to ensure the repeatability of the maf housing area in the intake is cnc machining a metal, most specifically aluminum.
There are no intakes available (other than our Stage III maf tube) that are made with a cnc maf housing.  ITG uses a metal tubing that has fantastic tolerances but they are as expensive as cnc machined housing whereas the waste during quality control when measuring the internal diameter of the maf sensor location is very high.  ITG has recently changed manufacturers of the metal tubing to find a way to reduce costs but that resulted in random tolerances like all other intakes face and they are about to release a machined insert for their intakes that fixes the issue.
That being said, the problems you guys "feel" with different intakes and the different results people experience with the same intake are all due to wide variances in the size or diameter of the maf sensor placement.  Some other intakes have some inherent design flaws as mentioned above that exacerbate this problem even further but most people know which ones those are and generally stay away from them.
Scientifically and completely without doubt, a properly designed and manufactured intake for a 2.0T FSI with k03 or k04 turbo will result in faster spool, better throttle response, more top end power, better fuel economy and overall increases in the efficiency of the engine's operation.  Any results that you guys have experienced that differ from this are due to the maf sensor placement, manufacturing repeatability or a design mistake.
APR and Carbonio tried to bring a design similar to our 2.0 TSI Stage 2 intake pipe to market that would also use our 2.0 TSI Stage 1 intake like pictured at the beginning of this thread.  We tested 10 of an initial run and all was well.  However, we then ordered an initial production run of 200 and found that random sampling resulted in random results and never released the product as we've searched for a better solution.
ITG makes the intakes for VWR and APR and Carbonio tested those intakes to find that the repeatability was very good and the best we had tested.  Therefore, APR and Carbonio abandoned the Stage 2 intake project and we recommend the VWR intake to 2.0T FSI clients that want more than our current Carbonio intake, which consists of a new front scoop and panel filter for the standard airbox.  The caveat as mentioned above is that ITG switched tubing vendors and had to develop the insert to correct the issue presented by the new tubing vendor.
The standard airbox cares about a lot more than response, fuel economy, power output and efficiency.  NVH, which stands for noise, vibration and harmonics, is a separate engineering discipline that is accomplished after the initial engine design and is a science of restriction regarding intake systems.  Much like exhaust systems, the only way to reduce NVH in an intake system is to add restriction.  This means that there are almost always gains to be had when replacing the standard airbox simply by undoing the design characteristics dictated by a desire to reduce NVH in standard cars.  Also, OEM's are almost always looking to reduce costs and the filters used are very restrictive as well because to get high filtration and low cost, the filter has to be restrictive, no way around it.  To maintain the level of filtration but get a better flow you have to move to a cotton gauze or foam filter and the costs are much higher for these kinds of filters.
If you feel your intake is not doing its job, there are simple testing procedures you can do....
A. Replace the intake with standard airbox and see if things are better
B. Use VCDS to determine your long term fuel trims and ensure they are within +/- 0-5%
Offline Keith@APR
  • -Receive: 36
    • Go APR
Re: APR TFSI intake
« Reply #25 on: December 12, 2012, 12:53:51 pm »
Funny you post this whilst I am in the midst of typing out an hour long diatribe to explain things.  :P :signLOL:
Offline Keith@APR
  • -Receive: 36
    • Go APR
Re: APR TFSI intake
« Reply #26 on: December 12, 2012, 01:05:41 pm »
Do you mean to say the APR Carbonio pictured is the same as an ITG?  If so, they do not share any parts, are designed and manufactured by completely different companies and the APR Carbonio front part of this intake was available way before the ITG/VWR canister intakes.
  • -Receive: 291
Re: APR TFSI intake
« Reply #27 on: December 12, 2012, 01:50:02 pm »
...manufactured with methods that do not allow for precise enough tolerances regarding the diameter of housing around the sensor and can be too large and too small to a point that creates improper maf readings....
...a properly designed and manufactured intake for a 2.0T FSI with k03 or k04 turbo will result in faster spool, better throttle response, more top end power, better fuel economy and overall increases in the efficiency of the engine's operation....
Stupid question (since I'm not very mechanically minded when it comes to cars) but how much variation did you find in maf readings? How did this translate in to figures we can understand like bhp?
If a variation of, say, +/-1% creates a variation of +/-1 bhp, then no big deal (IMO) since you can get greater variability in bhp from atmospheric conditions. But this is completely different to say a variation of +/-1% causing a variation of +/-10bhp since this would be noticeable. Would be interested in your interpretation of the results.
Offline Keith@APR
  • -Receive: 36
    • Go APR
Re: APR TFSI intake
« Reply #28 on: December 12, 2012, 02:01:45 pm »
Unfortunately, it doesn't translate directly to BHP but effects things like how much fuel the ECU applies.  The maf tells the ECU how much air is coming in to the engine and then the ECU uses this info in a bunch of different calculations to inject the proper amount of fuel.  If the maf reading is not precise, the ECU puts the wrong amount of fuel in, either too much or too little.  The oxygen sensor then reads the actual amount of fuel and air burned and reports that back to the ECU.  If the ECU was wrong because the maf data sent to it was wrong, it tries to fix the problem with the information the primary oxygen sensor gave it by changing the fuel trims.  The ECU is now very confused.
When the ECU is confused and is trying to fix the confusion with fuel trims, all sorts of weird running issues can happen.  It can be a lack of power, it can be misfires, it can be slow response, it can be hesitation, etc.  The more the ECU tries to fix the confusion, the more the ECU gets confused.  In some circumstances, the ECU can run leaner than its supposed to which might even make more power!
Its the old adage of Garbage In, Garbage Out when dealing with computers.  If the data the maf is sending to the ECU is incorrect, what the ECU tells the rest of the engine to do will be incorrect also.
I'm sorry there is no easy answer but modern internal combustion engines and their ECU's are very complicated systems.
The biggest problem with this entire situation is that one intake may work perfectly but the next intake from the same company, same part number can cause problems for that purchaser.
The maf is one of the most important sensors on the ECU.
Offline Janner_Sy
  • -Receive: 113
Re: APR TFSI intake
« Reply #29 on: December 12, 2012, 02:22:41 pm »
 :confused:
