Author Topic: DanGB's Leon Sport TFSI 4WD Sleeper - The End  (Read 98222 times)
Offline Janner_Sy
  • -Receive: 113
Re: DanGB's Leon Sport TFSI
« Reply #30 on: April 23, 2012, 01:03:43 pm »
They said the would do it for mine as well, although ive changed my plans on that front. Cooling is no longer an issue
« Reply #31 on: April 23, 2012, 01:19:34 pm »
is work no loner an issue, part timer??  :fighting:
I will ask keith about WMI Adjustments  :innocent:
« Reply #32 on: April 23, 2012, 02:12:42 pm »
WMI with a 50/50 mix should be the equivalent of permanently running 110+ Ron race fuel with the supercooling of a hyper efficient intercooler. This allows you to run much more timing advance without the ecu giving any pull. Should give a good 20+ bhp extra over stage 2+ with the higher mapping to take advantage of the WMI.  :happy2:
Offline DanGB
  • Different
« Reply #33 on: April 23, 2012, 05:41:19 pm »
Worst case scenario has come true. the disc has welded to the flywheel. New clutch time.  :sick:
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline djhorace
« Reply #34 on: April 23, 2012, 06:21:12 pm »
Not handy Dan - Any ideas which one you fancy replacing it with?
How have you found the 888's so far by the way?
« Reply #35 on: April 23, 2012, 06:24:27 pm »
what clutch kit is in your car ?
Offline chungster
« Reply #36 on: April 23, 2012, 07:25:44 pm »
According to his first post a Southbend stage 4 kit with lightened flywheel
But he's had that for a few years and giving it some serious abuse!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=r9ae64ntk90hsh8fak51qbh4df&/topic,19740.0.html
« Reply #37 on: April 23, 2012, 07:30:52 pm »
So that was you, i drove past you... if i had know i would have stopped!  :sad1:
Offline DanGB
  • Different
« Reply #38 on: April 23, 2012, 08:08:40 pm »
Going for a Southbend Stage 3 clutch -ie; not feramic material, so no chance of welding this time.
R888's seem good, not really pushed them yet, not sure on the noise as had the seats stripped out at the same time, but they feel good :)
Offline DanGB
  • Different
« Reply #39 on: April 23, 2012, 08:09:13 pm »
I wondered if you were off the forum  :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #40 on: May 04, 2012, 11:40:31 pm »
Saw your dyno graph today whilst me and mike were at APR   :surprised: :surprised: :surprised:
That car must be absolutely immense now!!!!!!! :party:
Offline DanGB
  • Different
« Reply #41 on: May 05, 2012, 09:11:58 am »
I aint seen??!  :laugh:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #42 on: May 05, 2012, 09:43:58 am »
 :driver:
Offline DanGB
  • Different
« Reply #43 on: May 22, 2012, 12:04:41 pm »
In a way it actually feel's slower now as the map is so much more linear, meaning I can actually get most of the power down in 3rd gear and some in second now at full throttle.  :signLOL:
Offline DanGB
  • Different
Re: DanGB's Leon Sport TFSI - Exhaust upgrade
« Reply #44 on: May 22, 2012, 12:09:56 pm »
Bit of an update.
Had the intake cam repalced due to it causing excess and uneven wear on the cam follower. We found it already had a B cam in it.
Also had a new exhaust fitted. Previously had a 2.75 milltek all the way, now have a 3" APR RSC full system, currently with a sports cat, but that might go soon!
This exhaust sounds very different than the milltek, similar at WOT, but low revs it sounds much more straight through and gives some subtle popping and occasional bang.
Very quite on motorway driving which is nice, as I currently have the rear seats removed.
I much prefer the tips on these rather than the old milltek, and they are easier to clean!
« Last Edit: May 22, 2012, 12:42:54 pm by DanGB »
