Author Topic: JBS K04 cast manifold in development.  (Read 3484 times)
« on: May 09, 2009, 04:18:42 pm »
JBS are developing a K04 cast manifold....
http://uk-mkivs.net/forums/t/269874.aspx
They have already developed a K03 cast manifold and ....so far...have had good results from testing...
http://uk-mkivs.net/forums/t/219683.aspx
I have a few questions for any engine guru's out there.
If the K04 manifold could produce similar results as the K03 version (50% flow increase), how much benefit would you possibly see in terms of power output?
Could it simply be that a K04 manifold strapped to a modified ED30 would simply mean that it wouldn't suffer from heatsoak as much?
Any other benefits?
Re: JBS K04 cast manifold in development.
« Reply #1 on: May 09, 2009, 07:29:18 pm »
iirc that manifold is for the mk4
Offline chungster
« Reply #2 on: May 09, 2009, 09:59:31 pm »
yup, they even posted a pic comparing it to the normal manifold with "BAM" on it, which was the 1.8T 225ps motor.
No point for our engines, as the manifold / turbo are integrated / 1 piece. The old style was seperate so designing a more efficient exhaust manifold for the turbo was beneficial.
« Reply #3 on: May 09, 2009, 11:05:18 pm »
^ K03 turbo integrated with manifold on Mk5 (mine!) ^
« Last Edit: May 10, 2009, 12:44:05 am by RedRobin »
« Reply #4 on: May 09, 2009, 11:24:46 pm »
Well, you learn something new every day.  8)
Offline neg
  • gone old skool
« Reply #5 on: May 10, 2009, 01:26:37 am »
Looks like they have moved away from the equal length one then... not that it fit so I'll keep stum  :laugh:
Offline bennylenny88
  • needs moar lowwww
« Reply #6 on: May 10, 2009, 01:50:54 am »
is there any part of your car that isnt touched RR?
Offline chungster
« Reply #7 on: May 10, 2009, 10:13:30 am »
RR needed a replacement turbo due to a slight crack losing him precious boost and bhp.
« Reply #8 on: May 10, 2009, 11:29:45 am »
^ Crack in the manifold casting of the turbo wastegate ^
Linky : - Troubleshooting a Boost Leak....
