Author Topic: walk kit not very effective  (Read 1003 times)
Offline heady2010
« on: April 01, 2012, 07:11:35 pm »
Just fitted a second hand walk kit and to be honest i can't really tell much difference. The only thing i did notice when fitting was that the inner piece of the bush wasn't the tightest fit to the bottom arm, possibly causing unwanted movement? Anyone had similar experience?
Offline Little_Dave
Re: walk kit not very effective
« Reply #1 on: April 01, 2012, 07:51:31 pm »
Can't speak for a 2nd hand kit but the new kit i fitted made a noticable difference to handling, how old is the kit you got and how many miles has it covered? Believe you can get new polybush inserts for them too  :happy2:
Dave
Offline dan930
  • -Receive: 56
« Reply #2 on: April 01, 2012, 08:03:53 pm »
Did yr steering feel more heavy??
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline gazon69
« Reply #3 on: April 02, 2012, 10:04:26 am »
Are you just running walk? Any other suspension mods? I think the main thing its meant to do is reduce wheel hop, which mine does excellently. Personally i haven't really felt much advantage in handling as i am running stock springs and dampers. I have recently added an autotech arb to the rear which has vastly improved handling and will add to that when i my bilstein b12 kit.
« Reply #4 on: April 02, 2012, 10:08:39 am »
Did you have geometry / alignment done afterwards?
