Author Topic: Running a Power Cable  (Read 2050 times)
Offline Smudgster
« on: May 09, 2009, 05:10:35 pm »
Im looking to run a power cable from battery to the boot to power an amplified Infinity Baselink. I had a quick look today and at first glance i couldnt see and easy wasy from engine bay into the passenger compartment. Anyone out there with some tips and tricks or howto's???
Smudgster
Re: Running a Power Cable
« Reply #1 on: May 09, 2009, 05:18:35 pm »
i read some where,if you take the battery out you can see a gromet in the bulk head
« Reply #2 on: May 11, 2009, 10:28:17 am »
i nearly put up a post like this but i just figured it out myself.
basically...take out the battery...and you can see the grommit that goes thru the bulkhead. take out the glovebox too and you can see where the cables come thru. then you can wire the cable to the boot under the sills! ;)
Offline Smudgster
« Reply #3 on: May 18, 2009, 06:54:52 pm »
thanks both all snorted now
Offline Gti Jal
« Reply #4 on: December 19, 2009, 06:40:58 pm »
Guys,
have you got power, speakers and RCA down one side? Any issues?
« Reply #5 on: December 20, 2009, 09:32:40 pm »
if you run all the cables down the same side you will get interference.You need to put the power cables down one side & the speaker cables down the other
Offline Gti Jal
« Reply #6 on: December 20, 2009, 09:48:28 pm »
I put the power and remote turn on down the sill and RCA & Speakers down the centre. Will find out tomorrow if its ok.
Offline paulk
« Reply #7 on: December 20, 2009, 09:50:45 pm »
you might get away with it if they are really good cables as its just for a sub...
