Author Topic: garage flooring ideas needed.  (Read 1573 times)
Offline Snoopy
  • -Given: 31
« on: April 03, 2012, 02:19:19 pm »
Currently its Dusty concrete 20ft x 20ft
Offline Matto
  • -Receive: 116
Re: garage flooring ideas needed.
« Reply #1 on: April 03, 2012, 02:26:33 pm »
You could sweep it well, PVA it to keep the dust down then use some heavy duty floor paint. This is what I'm going to do when I get round to it I think.
« Reply #2 on: April 03, 2012, 02:30:39 pm »
Mine is swept concrete but I always keep some large pieces of brown corrugated cardboard under the engine area so I can instantly spot any leaks.
« Reply #3 on: April 03, 2012, 02:30:51 pm »
black rubber stable matting  :happy2:
h4rdy
« Reply #4 on: April 03, 2012, 02:31:23 pm »
I have aluminium chequer plate which was being thrown away at work due to a hole being in the wrong place.
Enough for a whole garage but expensive to buy.
« Reply #5 on: April 03, 2012, 02:33:51 pm »
....I know that stuff only too well from when I used to work with horses. Don't get the cheap versions - They don't lie flat and gather rubbish at the joins. In fact, personally I wouldn't recommend rubber stable matting in a vehicle garage at all. Sorry, VC, is that what you use?
« Reply #6 on: April 03, 2012, 03:02:10 pm »
heavy weight stuff stays flat mate, has grips so doesnt matter with spilt fluids (else horses would slip if you keep them in your garage), wipe clean, trolley jacks grip it, protects floor from dropped equipment.
theres loads of types
« Reply #7 on: April 03, 2012, 03:14:51 pm »
I keep 270 horses in my garage.  :grin:
Yep, I can see the sense if you get good quality versions.
« Reply #8 on: April 03, 2012, 03:44:25 pm »
I keep under 250 horses in my garage.  :grin:
Corrected for recent Golf+ magazine readings  :booty: :signLOL:
On topic, I painted mine after PVA sealing it, but over the years it has become a little tatty, so I'm interested in this too. :happy2:
« Reply #9 on: April 03, 2012, 03:48:42 pm »
....Hopefully to be further corrected at JKM tomorrow. [Thinks to self: Can I sue Golf+?]
« Reply #10 on: April 03, 2012, 03:53:46 pm »
I painted mine.  :happy2:
Emerging from. by T0P cat, on Flickr
« Reply #11 on: April 03, 2012, 03:57:33 pm »
Any special kind of paint, TC? And has it stayed so pristine?
« Reply #12 on: April 03, 2012, 04:06:31 pm »
Yes! you need two pack paint if i remember correctly, and it has held up well, it could do with a quick wash, but apart from that it still looks bright.
Offline glenn_g60
  • Red Ed30 No. 884
« Reply #13 on: April 03, 2012, 04:36:20 pm »
I painted mine with some normal concrete paint after a brush out. Thou has started to come off when sat wet wheels on it. Not too bad mind.
Offline Snoopy
  • -Given: 31
« Reply #14 on: April 03, 2012, 05:10:44 pm »
My floor does seem to give off lots and lots at concrete dust.
Just been reading on the net about tiles and resin finishes too. Some interesting finishes out there
Not sure how to get the floor concrete dust clean enough before sealing
