Author Topic: No AM signal  (Read 1106 times)
Offline drexel75
No AM signal
« on: April 05, 2012, 03:22:27 pm »
I have a 2007 model GTI with a beesting aerial. I believe the car also has an aerial in the rear window. As the title suggests I can not get any AM reception at all. I have had the head unit out to check that the aerial is connected. Both were connected and it was the 2-in-1 style block connecter so they had to be the right way around. Am I right in saying that the AM signal comes solely from the rear window? I am wanting to take the trim off and check the connections around there. Is there some kind of connection underneath the trim?
I know most folk don't bother with AM nowadays but it's still great for sport when you don't have DAB.
I have an RCD300 stereo.
« Last Edit: April 05, 2012, 03:31:31 pm by drexel75 »
Offline Gtiain
Re: No AM signal
« Reply #1 on: April 05, 2012, 03:23:56 pm »
+1
I don't  have any am signal either and as you say it's good for sport.
Offline drexel75
Re: No AM signal
« Reply #2 on: April 24, 2012, 05:08:32 pm »
Does nobody have any ideas on this? Come on guys. Any help much appreciated.
Offline Gazza747
Re: No AM signal
« Reply #3 on: April 24, 2012, 05:53:18 pm »
The antenna on the rear window only sends an FM signal. The roof aerial sends FM and AM signals. The antenna on the back window is amplified but the roof aerial is not.
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline drexel75
Re: No AM signal
« Reply #4 on: April 24, 2012, 07:57:23 pm »
Thanks for that. I'll need to get the roof lining out and check to see if the connection is loose or not made.
