Author Topic: warrent aircon issue  (Read 1899 times)
Offline stevie_p
« on: May 10, 2009, 02:18:40 pm »
hey chaps, car goin into stealers 2moro for them to have a look at the aircon (isnt blowing cold). just wanted to know if i will get charged anything for labour etc??? cars under warrenty 56-plate gti & only had it for 9 weeks. following a previous thread on here i want them to check the compressor rather than just tell me it needs a re-gas!!
cheers
Offline mortygttdi
  • -Receive: 146
Re: warrent aircon issue
« Reply #1 on: May 10, 2009, 04:07:34 pm »
They will do a full dye and compression test on the aircon I had this done but not under the warranty. I needed an aircon pipe changing and it cost me £350, but for you they should do it free has it is under warranty.
But don't worry they will check it for you not just visually.
Darren
Offline neg
  • gone old skool
« Reply #2 on: May 10, 2009, 04:46:49 pm »
Should be free if under warranty - mine's has 2 compressors in its life so far.
Offline stevie_p
« Reply #3 on: May 10, 2009, 05:54:08 pm »
ok cheers dont fancy a big bill after a few weeks of ownership!!!!
« Reply #4 on: May 10, 2009, 07:52:41 pm »
 :scared: :scared:
Offline neg
  • gone old skool
« Reply #5 on: May 10, 2009, 11:49:20 pm »
and 2 sets of door seals  :grin:
teething problems!  Also it probably could have been fixed but the mechanics technicians just replace the lot when its under warranty.
Offline deccae
« Reply #6 on: May 10, 2009, 11:52:26 pm »
I've had the compressor & condensor replaced on my 2005 2.0 fsi (non turbo).
I was advised to have them both replaced as the compressor had seized and
this can cause fragments to remain in the system which could damage a new compressor.
Anyway as i was out of warranty it cost me £1400 all in.
This was at an independant by the way.
Offline stevie_p
« Reply #7 on: May 13, 2009, 12:02:56 pm »
just had call from stealers a new compressor is on order!!!!  so much for it just needing a re-gas eh!!! must be a major problem with the compressors on the air con, with so many ppl having them replaced. lucky im under warrenty!! :happy2:
