Author Topic: New pcv valve now car running rough  (Read 8209 times)
Offline mk5craig
« on: April 07, 2012, 11:57:07 am »
Hi, have just fitted a new pcv valve as my old one was broken, i fitted part no 06f 129 101 p which vw said was the newest one
picture shows old one on car and new one above it
fitted it and started car and its hunting and revving all over the place, is it now i have fixed this it has hi9ghlighted another fault if so what or is it the wrong part or ?
any help would be much appreciated
thanks craig
Offline Richn83
  • -Given: 49
  • -Receive: 85
Re: New pcv valve now car running rough
« Reply #1 on: April 07, 2012, 12:02:12 pm »
The newer pcv's have an additional check valve in one of the pipes if your car is older you need to change the pipe as well or stick to a certain revision before the check valve was added.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #2 on: April 07, 2012, 12:03:20 pm »
I had this when i replaced a PCV for a later version.
I took it off and got the same part no. as the one fitted and that cured the problem.
Offline mk5craig
« Reply #3 on: April 07, 2012, 12:05:22 pm »
Thanks for your help, will leave old one on for know and get a hose order tuesday
thanks craig
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: April 07, 2012, 12:09:30 pm »
I think i remember reading anything past revision "N" will need the new check valve  :happy2:
Offline Thor
  • -Receive: 25
« Reply #5 on: April 07, 2012, 02:53:54 pm »
I replaced mine with the N version - Part no. 06F 129 101 N a couple of weeks ago and all has been fine, certainly not had any rough idling.  Guess you'll need the new check valve as Fab5freddy says.  :happy2:
                                     Mk6 GTI
Offline 56OctyVRS
  • -Receive: 72
« Reply #6 on: April 07, 2012, 03:27:00 pm »
If your car is an early one it will need the N revision valve. If your car is circa 2007 then it will need the P revision valve. If your is the later one id say your rear check valve is broken and needs replacing. Or you could just fit the N revision and not bother with the rear breather hose.
Offline 56OctyVRS
  • -Receive: 72
« Reply #7 on: April 07, 2012, 04:12:05 pm »
Just seen your car reg in the members rides. You need the N revision as yours is a 2006 model.
Offline mk5craig
« Reply #8 on: April 07, 2012, 04:54:57 pm »
Ok, thanks for the responses, will order a version N
Will put the version P on here for sale
Thanks craig
Offline mark53
« Reply #9 on: April 07, 2012, 05:35:23 pm »
Is 06F 129 101 L not the right part number?
Offline 56OctyVRS
  • -Receive: 72
« Reply #10 on: April 07, 2012, 07:24:29 pm »
The N replaced the L revision
Offline mark53
« Reply #11 on: April 07, 2012, 07:33:42 pm »
So if I had this pcv 06F 129 101 F on my car,which would be the correct  revised part number I would need the cars a edition 30 2007
Offline 56OctyVRS
  • -Receive: 72
« Reply #12 on: April 07, 2012, 08:52:53 pm »
If you have the F you need the N :happy2:
