Author Topic: AndrewJB's MK2 Leon FR TDI "Der Rote Baron"  (Read 16395 times)
Offline AndrewJB
  • die gelbe Baron
Re: AndrewJB's MK2 Leon FR TDI "Der Rote Baron"
« Reply #15 on: April 09, 2012, 07:52:41 pm »
The only think putting me off one of the kits was the fact it used the 312mm dics, which IMHO are to small for 18" wheels
Porsche Calipers + 345mm discs would be ace
« Reply #16 on: April 09, 2012, 07:57:24 pm »
Mine are 350mm mate  :happy2:  with 996tt calipers.  I used to have the 312mm kit and it was very very good for a number of reasons but the bigger kit is ace
http://www.mk5golfgti.co.uk/forum/index.php/topic,42137.0.html
**EDIT
You'll see alot of reference on here tho the NQSBBK - Its the "Not Quite So Big Brake Kit" that uses the 312mm & Boxter caliper, plenty of threads on here  :smiley: :happy2:
« Last Edit: April 09, 2012, 07:59:09 pm by Tfsi_Mike »
Offline AndrewJB
  • die gelbe Baron
« Reply #17 on: April 09, 2012, 07:59:03 pm »
Would the 350's fit behind my BTCC Wheels
« Reply #18 on: April 09, 2012, 07:59:55 pm »
What offset? I needed a 3mm spacer with TD Pro race 1.2 ET45 I think mine are
*edited post above ref NQSBBK
Offline AndrewJB
  • die gelbe Baron
« Reply #19 on: April 09, 2012, 08:02:37 pm »
Dunno i dont understand wheel offsets hence why ive never changed wheels  :grin:
« Reply #20 on: April 09, 2012, 08:06:23 pm »
As far as I understand a lower offset will give you more clearance inside the wheel and between wheel & shock but will stick out more
For example
OEM Cupra wheels were ET51
New wheels are ET45 so poke out 6mm more but give 6mm more room inside  :happy2:
Somebody correct me if Im miles off
Offline AndrewJB
  • die gelbe Baron
« Reply #21 on: April 09, 2012, 08:14:48 pm »
Dropped Dave an Email!  Really neeed to get front end knocking sorted out first though, Top Mounts suspected
« Reply #22 on: April 09, 2012, 08:17:02 pm »
Got a quiet knocking from front / front left atm too.  Had new top mounts, arb bushes, track rod ends, console bushes.
Theres a subframe bolt replacement discussed on here that Im going to try.
Offline AndrewJB
  • die gelbe Baron
« Reply #23 on: April 09, 2012, 08:32:29 pm »
Yeh the longer bolts with a little metal washer thing, might try them first as there cheap
« Reply #24 on: April 09, 2012, 08:32:37 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,23845.0.html
Mee too
Offline AndrewJB
  • die gelbe Baron
« Reply #25 on: April 09, 2012, 08:58:43 pm »
So should be able to get these from TPS
Offline damoegan
« Reply #26 on: April 09, 2012, 09:11:27 pm »
I've got the same thing.. Fitted new console bushes, new ARB bushes and new drop links without sucksess  :sad1: :sad1:
New topmounts sitting here ready to fit..
Offline vRSAlex
  • -Receive: 253
« Reply #27 on: April 09, 2012, 09:14:14 pm »
With wheel clearance, you can have an et30 wheel that has less clearance at the back of the spokes than an et50.  All really depends on the style of the wheel.
I suspect you would need ay least a 10mm spacer to get the btcc wheels over the 996t calipers.  There should be loads of arch clearance to allow a good size spacer.
Follow AKS tuning on Facebook
Offline AndrewJB
  • die gelbe Baron
« Reply #28 on: April 09, 2012, 09:15:26 pm »
Im going to Try these subframe bolts first then if not probably Top Mounts
hopefully going to get Alex at AKS to do it
Offline damoegan
« Reply #29 on: April 09, 2012, 09:22:27 pm »
I've been thinking of these too. Let me know how you get on matey  :happy2:
