Author Topic: Stage 2 or 2+ on a k03????  (Read 1892 times)
Offline Ducky76
« on: April 11, 2012, 01:41:07 pm »
He there in just about 2 order a blueflame tbe do I need 2 stage 2 it or should I 2 + it what's the pros and cons of both options cheers andy
Offline Sammy
Re: Stage 2 or 2+ on a k03????
« Reply #1 on: April 11, 2012, 02:03:59 pm »
Stage 2 is good for it, It will take out the exhaust light that may come up and also writes out the second sensor on the cat/decat
GTI MK5 with all the gooodies
K04 power going on soon!
« Reply #2 on: April 11, 2012, 02:58:46 pm »
You need an uprated hpfp for stage 2+.
Offline Ducky76
« Reply #3 on: May 22, 2012, 01:46:11 pm »
Hi I've wondered the same I've just had the blue flame tbe with back box delete fitted and have stage 1 and intake so is it realy worth the 300£ for stage 2 when gaining minimal bhp or would 2+ be worth it or just leave I have no lights on dash all good cheers ,
Offline GarethB
« Reply #4 on: May 22, 2012, 01:58:24 pm »
What software are you using?
When I have discussed stage 2 with JKM, I was told that they load a slightly 'watered down' Revo Stage 2 to K03 cars to avoid fuel cuts.
In their opinion, the standard fuel pump can't handle Stage 2, and suggest the use of an uprated HPFP for best results.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: May 22, 2012, 02:48:08 pm »
a few members of VAGOC are of the opinion that Stage 2 is just an exhaust light delete and doesn't actually give any noticable power increase (tho to be fair most of them are S3/TT-S owners)
tbh mate i'd jump straight to Stage 2+. i'm jumping straight to Stage 2+ from a standard map once i get a chance to get my car off the road lol
PLANS: Stage 2+
Offline edd666999
  • -Receive: 89
« Reply #6 on: May 22, 2012, 03:46:24 pm »
the 2+ map adds power mid range and gets rid of a small flat spot i believe.
I recommend getting the fuel pump as a stage 2 map is pushing the pump afaik
Offline Ducky76
« Reply #7 on: May 22, 2012, 04:04:10 pm »
Think il leave alone then just stay stage 1 it drives like a animal as it is
Offline gigolo456
« Reply #8 on: May 22, 2012, 04:35:51 pm »
I have heard a few VAG specialists state that a HPFP is not needed on a KO3 engine for a Stage 2, only Stage 2 +....
 :confused:
Offline edd666999
  • -Receive: 89
« Reply #9 on: May 22, 2012, 04:42:21 pm »
 :confused:
this is true.
Offline gigolo456
« Reply #10 on: May 22, 2012, 04:58:24 pm »
But did you not advocate getting a HPFP for Stage 2 in an earlier reply??
Andrew :confused:
Offline edd666999
  • -Receive: 89
« Reply #11 on: May 22, 2012, 05:00:37 pm »
yeah  :smiley:
but i didnt say it was needed, i just said id do it because imo a stage 2 map is pushing the pump, to avoid fuel cuts and to give a bit of head room id do it  :party:
Offline gigolo456
« Reply #12 on: May 22, 2012, 05:03:56 pm »
oh right, well when i get a custom remap Stage 2, i am hoping they will take everything like this into account!?
