Author Topic: neuspeed p-flow intake  (Read 1872 times)
Offline badbwoy27
« on: April 11, 2012, 05:23:02 pm »
was thinking about purchasing one of these intakes  for my stage 1 golf gti mk5 k03.I no alot of the yanks rave on about them over there, and on awesomes web site they say the intake comes with the correct size maf housing so to not mess up fuel trims.just wondered if anybody has one of these intakes, or any info good or bad so that i can make up my mind on buying one.thanks. would also get the evoms heat shield from regal if i did decide to purchase.
Offline Dan648v
  • -Given: 28
Re: neuspeed p-flow intake
« Reply #1 on: April 11, 2012, 05:40:38 pm »
I run one on my stage 2 ed30 and have no problems with it, I like the sound it gives off and the fit and build quality was good!
Offline badbwoy27
« Reply #2 on: April 11, 2012, 05:46:42 pm »
didnt think they would have any problems cause suppose as long as u get the correct maf housing they all do the same thing and function in the same way.basically it just a filter on the end of stick.
Offline Dan648v
  • -Given: 28
« Reply #3 on: April 11, 2012, 05:52:54 pm »
In a sense yes, I may swap the filter element for a k&n one eventually but it was enough to help make 305bhp @the wheels on my ed30! Can't remember my inlet temps but i will be running a cold air feed to the filter cause it's close to the radiator and abit out in the open! But for the price I'm not complaining
« Reply #4 on: April 11, 2012, 06:07:53 pm »
Are you running a stage 2+ map as that whp as that translates to around 350 bhp @ flywheel...
Offline Dan648v
  • -Given: 28
« Reply #5 on: April 12, 2012, 10:02:16 am »
It's a stage 2 revo map and was dyno'd on a hub dyno in Doncaster at RDT. Could probably benefit from going stage 2+ or just adding a hpfp as I have a dip in the mid range where the standard pump is struggling.
Offline robdf2
« Reply #6 on: April 12, 2012, 01:27:00 pm »
Im pretty sure they are K&n filters on them anyway , impretty sure mine is on my P flow
and it contains the same dye as used in k&n filters.
2008 Chrono yellow Cupra
Offline Bogwoppit
« Reply #7 on: April 12, 2012, 01:33:49 pm »
This is the K&N filter which fits the neuspeed P-Flow, it's nearly identical to the one that comes with the Kit and is the same one that K&N use for their TFSI intake.
http://www.opieoils.co.uk/p-68837-kn-ru-4960-performance-air-filter-universal-rubber-filter.aspx
I used it on my P-Flow without ay problems
Offline PSItuning
  • Trader - 2014
    • PSItuning.com
« Reply #8 on: April 12, 2012, 01:49:45 pm »
Yes neuspeed filter is a K&N one...
Great intake for the price and sounds good too!
http://www.psituning.com
Suppliers of ECS Tuning, Milltek, KW, AP, Revo, Forge, Wavetrac, Brembo, Superpro, Newsouth, CTS Turbo, Powerflex, VWR, Jetex, Polybush, Vibratechnics, K&N, Green Filters, Tarox, Meguiars, H&R, Eibach to name a few!
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #9 on: April 12, 2012, 02:03:21 pm »
Do you sell them? Price please...
Diesel Daily Hack.
Offline PSItuning
  • Trader - 2014
    • PSItuning.com
« Reply #10 on: April 12, 2012, 02:04:36 pm »
