Author Topic: Rear wiper replacement  (Read 5334 times)
Offline flywalker
« on: May 12, 2009, 12:35:24 pm »
Having had problems with the rear wiper on my 05 GTI,  I've decided to replace it with a wiper motor  I got from ebay. I found VERY CHERRY s post with how to remove/replace the rear wiper motor but does anyone know is removing the " lower rear  lid (hatch) trim" to get access to the motor easy ?  Any tips as where to start or how to.. without damaging the trim ?
Offline joesgti
  • Eat my sick, Eat my sick.
Re: Rear wiper replacement
« Reply #1 on: May 12, 2009, 01:28:36 pm »
pull it very very hard!! it will feel like its going to snap but it shouldnt!! i did mine when removing my wiper, cant get it back on propably though,  :rolleye:
Offline flywalker
« Reply #2 on: May 12, 2009, 02:58:25 pm »
Cool thanks .   Hopefully I have better luck getting the trim back on then ....
Offline VeeDubDan
« Reply #3 on: May 12, 2009, 04:10:26 pm »
Offline TomB
« Reply #4 on: May 12, 2009, 04:27:56 pm »
What was your wiper motor doing?  Mine's started wagging away every other startup and when it has a moment it stops anywhere it wants!
I swapped my inner lights the other day, I found that from the bottom was the best place to start when removing and at the top when putting it back on.  Don't forget to remove the 2 screws in the grab handles.
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline flywalker
« Reply #5 on: May 12, 2009, 05:27:51 pm »
The rear wiper  seems to have a mind of its own.  It would come on of it own accord at start up . Sometimes I could   switch it off other times I would have to turn off the  ignition to get it to stop.
Offline flywalker
« Reply #6 on: May 12, 2009, 05:31:01 pm »
Thanks VeeDubDan  thats just the job.
Offline flywalker
« Reply #7 on: May 17, 2009, 02:29:41 pm »
Just an update on the above.   The diagnosis of a wiper motor change to fix the rear wipers tendency to operate with a mind of its own was spot on. Thanks to info provided on this site I successfully replaced the wiper motor and it is  working as it should now. Aside from the money saved (bought from ebay 25 quid) there is a satisfaction in fixing the problem your self.
Thanks.
« Reply #8 on: May 17, 2009, 04:27:40 pm »
Why did you remove the entire trim as you should be able to change those lights just using the pop out pieces of trim at the sides.
« Reply #9 on: May 17, 2009, 05:46:49 pm »
glad your sorted  :happy2:
Offline neg
  • gone old skool
« Reply #10 on: May 17, 2009, 10:16:41 pm »
I have had this on mine in the past, replaced under warranty fortunately.
Offline TomB
« Reply #11 on: May 18, 2009, 01:26:39 am »
There's one bolt thats pretty tough to get at through the access panels, it was a lot easier to take the trim off than struggle with a spanner then lose the nut behind the trim!
Looks like the trim is coming off again then, I have the same issues with my wiper  :sad:
Tom
