Author Topic: Brakes  (Read 1732 times)
Offline Johnny_tro
Brakes
« on: April 13, 2012, 10:38:34 pm »
I have a 2004 GT TDI, please can you advise me..................
1. Whats the standard disc size?
2. GTI setup < are these the same calipers, just a bigger discs?
3. R32 < This would require new calipers, discs and custom brackets for the calipers?
Many thanks
Re: Brakes
« Reply #1 on: April 13, 2012, 10:54:47 pm »
standard disc are 288
gti                         312 i think
r32                         345
Offline Johnny_tro
Re: Brakes
« Reply #2 on: April 13, 2012, 10:59:22 pm »
I do need to do discs and pads all round.
Is a GTI setup easy enough to do? if they are the 312 will I need the calipers as well? and is it just a simple swap over?
Re: Brakes
« Reply #3 on: April 13, 2012, 11:34:09 pm »
think you need pad carrier to change to the gti ones
Offline Phil Miller
  • -Given: 86
Re: Brakes
« Reply #4 on: April 13, 2012, 11:34:44 pm »
GTI set up is just the GTI carriers and new discs, you can use your old calipers save having to bleed the brakes  :happy2:
Offline Johnny_tro
Re: Brakes
« Reply #5 on: April 14, 2012, 09:13:55 am »
Spot on........
So the only difference between the GT and GTI are the disc size.
Carrier < This is just the bracket (with two large bolts) that hold the caliper to the hub/frame basically? and by changing this it will hold the calipers out and a further distance for the gti discs?
and GTI are 312mm?
Offline skard
  • -Receive: 245
Re: Brakes
« Reply #6 on: April 14, 2012, 11:42:05 am »
From what I know standard GT170 brakes are the same as GTI (312mm fronts), so it's another option when searching for used ones.
Offline stevw1
Re: Brakes
« Reply #7 on: April 14, 2012, 03:54:51 pm »
GT TDI 140 = 28mm / GT TDI, GTI, = 312mm
All you need is the carrier and discs to convert to 312's  :happy2:
Currently in the process of completing this mod.
Offline Johnny_tro
Re: Brakes
« Reply #8 on: April 15, 2012, 09:29:48 pm »
 :happy2: Thanks all!!!
Anyone know a part number for the carriers?
and to be a pain........what about the rears?
